Results 1 to 10 of 12
Thread: Questions from a newbie
03-16-2008, 01:54 PM #1Senior Member
- Feb 2008
- Houston, TX
- 119
I recently bought a used 2005 Mobius LSV. I've been boating all my adult life, but this is the fist boat I've owned and my first real experience with inboards. I've done tons of research here and all over and I've gotten most of my questions answered, but I still have a few questions I couldn't find anywhere else. I've also been told and figured out some things about inboards (like most of them will only back in one direction and not too well at that!), but any other general tips about inboards or Moomba's is greatly appreciated.
I bought the boat from an individual, so I don't have a dealer to ask about this stuff (although I plan on having the local dealer give the boat a once-over very soon).
How do you run the motor out of the water?
For I/Os there's a little device you can buy that feeds water into the lower unit from a garden hose to be able to run the engine when not actually in the water. Is there a similar device for inboards?
How do you use the wakeplate?
We played around with this our first time out, but had trouble finding a good setting for 'the perfect wake'.
How do you raise the top white navigation light?
This is a pretty dumb one, but both my buddy and I fiddled around with this and couldn't figure it out and the instructions in the manual didn't help. It's a bit brittle already and I didn't want to force it and break something.
Where can I get Moomba parts?
I test drove another 2005 LSV that was a Gravity III. I'm not sure if this is just better equipped, but it had sweet Moomba branded pop-up cleats. I just assumed when I bought this other boat (a Gravity I) that it would have them also and didn't realize until I got it home that it doesn't have cleats at all. I would also like the buy the factory depth guage, which my boat doesn't have either.
Can anyone recommend a bimini top for this boat?
Thanks in advance and I will post pictures shortly.-ryan
'10 Wakesetter LSV
03-16-2008, 04:56 PM #2
Welcome to the Moomba Clan!
2 main options: Fake a lake.. looks like a toilet plunger. it attaches to the water intake on bottom of hull.
Perko Flush Pro 1 1/4" - This fits inline on your water intake hose between hull and where the intake goes into your trans/v-drive. I had one of these on my outback and it was great. If you plan on using lots, go with this. If you do this 1-2 times a year, go with fake a lake. (go to overtons, west marine, etc. and search fake a lake)
Many ride at 50% or 1/2.. lower and you'll get flatter wakes, higher and you'll get peakier ramps.. I usually keep it around 50% unless I decide to play a little..
on one side of the light, where the phillips head screw is, there is a piece that flips out... there are grooves that hold the light in place, when you flip this out, it loosens light.... yes it will break somewhere if you pull on the light and not flip this clip..
Find a dealer to order from.. Moomba generally will not sell parts direct. If there is not a dealer close, you can have them shipped from them. The cleats are nice.. ATTWOOD makes some just like the Moomba, just not laser etched. There is as post on here about upgrading to Grav. III. do a little searching and you should find it. I think there is mention of someone at Moomba who can give you a parts list.. You would probably want to get the 400lb fly high sacs for the back. 750's won't fit in your 05. There is a new 565lb sac that is said to fit.. Basically, you will need the evac pumps, hoses, switch panel with all 3 switches and the manifold/solenoid valves. I believe that the Grav III system uses one pump to fill all 3 so you should be able to utilize that. anyway, look for the post and you'll see where to look to order the entire kit. I have seen where some dealers will install for same cost of factory option ($800ish).
Depth finder.. there is nothing Moomba or specific about the depth gauge.
here are 2 affordable options depending on your installation prefs.
http://www.overtons.com/modperl/prod...ID=1008&r=view
Check Towerbiminis.comBrad
2006 Moomba Mobius LSV sold
2004 Outback sold
03-16-2008, 05:33 PM #3Senior Member
- Jun 2007
- 883
I have been afraid to lift my light too, feels like it will snap.
Stereo: Kenwood KMR-D562BT
Ballast: 750 Surfside locker, 400 Surfside mid boat, 400 Gravity I, 400 Bow
Surfboards: Inland Surfer Red Woody, Triple X Composite X 58"[/SIZE]
03-16-2008, 08:08 PM #4Member
- Mar 2008
- Frisco, TX
- 42
Speaking of the light and flipping thing... I went through the same thing and finally figured it out on my own. but my flipper did somehow broke the pin and will not stay on once i flip it down so i can get my light up. So I just have to flip it down, hold that part then set the light up then flip it back on. So just be careful when you flip it down. It can break easily. (my boat's 06 LSV.)
Since we're on the same page, is there any way I can fix it? More likely having to replace that flip thing.
03-16-2008, 08:34 PM #5
That light took me a while to figure out too. LOL, I feel better now.
It is better barefoot!
03-16-2008, 09:31 PM #6Member
- Dec 2006
- Alabama
- 54
Broke my light off before I ever put the boat in the water. I used duct tape to keep it up, when needed until I took the boat in for service. I forget what it cost for the replacement, but now I know how not to break it.
Neil
03-17-2008, 02:03 AM #7Junior Member
- Jun 2007
- Somerville, TX
- 29
Rinker's on Mount Houston is your local dealer. I bought my boat private as well and caught no hint of a problem with them when I took it in for a service a month or so ago. I could not recommend them enough. I recently ordered some items from them to update my boat and found that they sell at SC list, which is fair. I can tell you that a lot of car dealers mark up well beyond the MSRP on parts so I would guess that some boat dealers do as well.
Let me know if you will be coming to Lake Somerville some weekend soon. We live in Fulshear but recently bought some land up there. Conroe is a joke. Too many people there to be able to relax and have a nice time with the family.
Welcome. Believe me .... there are no stupid questions on this board. Use the search function and if that proves fruitless, just ask. This is a pretty cool group of enthusiasts!
03-17-2008, 08:36 AM #8Senior Member
- Mar 2006
- Chapin, SC
- 159
Operating your engine on the trailer is one thing, just do not put the boat in gear while on the trailer.
03-17-2008, 01:18 PM #9Member
- Feb 2008
- Dallas, Tx.
- 83
I'm sure you have figured out the light thing by now, but if you haven't the easiest way to losen the flap that you pull out to stand the light up, is by grabing a philips head screwdriver and ever so slightly loosening the screw that holds it in place. This should help out a bit for you, that's how I learned to make it work for me
Good to know it wasn't just me!Ridin' Dirty!
03-17-2008, 05:34 PM #10Senior Member
- Feb 2008
- Houston, TX
- 119
Whew I'm glad I'm not the only one that had trouble with the flip-up nav light.
Thanks for the manual picture post, 04OUTBACK. I noticed your manual says 2006, while mine is from 2005. My manual actually doesn't match what's on the boat and shows a round screw knob, which is why I just couldn't figure it out.
However, once we got the boat in the garage and worked on it, I noticed (like JD) that the screw was simply too tight and slightly loosening it allowed the lever to flip out. However, as I pointed out, it's brittle and had already broken before I bought the boat. However, it's working well now that I loosened the screw, so the broken bit doesn't seem to be hurting anything.-ryan
'10 Wakesetter LSV
considering 05 XLV - some questions
By tlatoani in forum General ChatReplies: 20Last Post: 12-01-2007, 08:38 AM -
Newbie queston about buying my first boat??
By jetlinking in forum General ChatReplies: 10Last Post: 07-05-2007, 07:37 PM -
Newbie needs help
By philjo in forum General ChatReplies: 14Last Post: 08-10-2006, 04:56 AM -
questions about XLV
By Jmo in forum Sales & InformationReplies: 3Last Post: 07-30-2004, 11:29 AM -
Another Question from a newbie
By ezreitter in forum Boat OwnersReplies: 1Last Post: 08-16-2003, 10:38 PM
