Results 1 to 10 of 15
Thread: Freezing Temps Tonights!!!!
03-03-2008, 06:13 PM #1Member
- Feb 2008
- Dallas, Tx.
- 83
How concerned should I be that we where out on the boat 2 days ago in 75 degree weather, and now we will dip just below freezing.... The boat was winterized before I took it out on Sat. but not any more. Should I be freaking out right now or is this something that as long as it isn't exposed to freezing tempatures for long should be okay?
Ridin' Dirty!
03-03-2008, 06:26 PM #2Senior Member
- Aug 2005
- 105
I live in wisconsin, and you should be fine if it only gets below freezing for the night. If it were below freezing for a couple of days then I would be a little worried. Must be nice to have been on the boat the other day. We hit 43 for the first above freezing day of the year. Today 27, over a 18 inches of ice on the lake.
Milwaukee, Wisconsin
03-03-2008, 06:59 PM #3Senior Member
- Dec 2004
- Cinci-Dayton
- 1,014
drop a trouble ligt into the engine compartment for a litlte insurance
03-03-2008, 09:10 PM #4
If the duration of the freezing is short don't worrying about it. Put a light into the compartment would be fine. Nowadays, you have to define the lightbulb. A light bulb that gives off heat not the energy saver ones. With technology you can get a clock that projects on the ceiling and take the sensor and put it in the engine compartment. You can stare at the ceiling all night seeing how cold your engine got (lol). Where I live I usually get do something if the temperature is expected to dip below 28 degrees.
03-03-2008, 09:16 PM #5Member
- Feb 2008
- Dallas, Tx.
- 83
Thanks for the posts guys I put two 75 watt light bulbs in compartment(one on each side) to be on the safe side, do you think this is too much/too little or just right?
Ridin' Dirty!
03-03-2008, 09:22 PM #6Senior Member
- Mar 2005
- t-town
- 718
i just live north of you in tulsa.
i have done what you did many times, taking the boat out for a day when it's nice after being winterized.
big question, is the boat garaged or not.
if not, i would drain the block and mainifolds.
if so, the light bulbs will be fine...
03-03-2008, 11:28 PM #7Senior Member
- Dec 2004
- Cinci-Dayton
- 1,014
And heater if you have one. In a garage you will be fine.
SD2
03-03-2008, 11:30 PM #8
One light should actually be enough! It has to stay cold for an extended period of time (days) before you do engine damage (cracked heads and/or block). It is 32 degrees at my place now, but it isn’t supposed to get that cold tonight. It only take a few minutes to take out the drain plugs from either side of the block though, and unhook the water hose to drain our exhaust manifolds, if you are concerned. You might make sure you have your ballast lines unhooked from your rear ballasts so that you can drain the lines and maybe even unscrew and empty your strainer on your ballast system….but with two lights under your hood, those roaches will be having a beach party tonight!
03-04-2008, 02:22 PM #9Senior Member
- Jan 2006
- Dallas, TX
- 113
I think it's just as easy to reach down and unscrew the two plugs on both sides of the engine block to let the water drain out.
GO BIG OR GO HOME!
03-04-2008, 07:00 PM #10Member
- Feb 2008
- Dallas, Tx.
- 83
Excuse the question but I'm a newbie at this whole V-drive thing
Anyone know if I'm just missing the screws on the block to drain it? On my DD boomerang it was a peice of cake....... is there an easy way to get to them on the V-Drive?Ridin' Dirty!
engine temps?
By bobwells in forum Service & RepairReplies: 3Last Post: 03-11-2007, 09:58 PM -
Water Temps....
By tallone31 in forum Wakeboarding | WakeskatingReplies: 19Last Post: 04-09-2006, 10:29 PM -
Water freezing in my boat??
By Nboard10 in forum General ChatReplies: 8Last Post: 02-08-2006, 11:47 AM -
freezing temp./engine
By barefooter in forum Service & RepairReplies: 4Last Post: 09-29-2003, 09:46 AM
