    Default What size hole for ballast bilge? Dual Battery question also
    About to drill 3 holes in my 05 lsv for my GG 3 bag upgrade and intergated bow sac. Anyone know the correct size hole saw i need to get? Any other tips on drilling this besides masking tape,drill in reverse at first,and clean up edges with a dremal.
    Also to the guys running two batterys with a perko. I kinda confused, #1 battery will be for starting the boat #2 battery will be for all boat accesories and my amps and leds. So how do i seperate the two?
    Is the 0 gauge power wire that is hooked to the battery the one that starts the boat, and the 8 gauge that goes into the breaker and then to the battery all the boats acessories?
    Aug 2006
    Salt Lake City
    I assume you mean the holes for the thru hull fittings? I just replaced all my with Chrome and the fittings were 3/4"...
    Brad
    2006 Moomba Mobius LSV sold
    2004 Outback sold
    yes that is what i mean, sorry couldnt remember what they were exactly called. You sure that is the size of the hole saw i need to buy that seems very small.
    Aug 2006
    Salt Lake City
    I would suggest drilling a piece of wood first and make sure thru hull fitting fits in... I just took mine back to storage or I would go measure. them.. I think there was a little bit of clearance on them but not much so maybe a small bit larger than 3/4.. you could take a piece of hose to home depot/lowes to look at saw and compre..
    Brad
    2004 Outback sold
    ok thanks anyone care to give me some info on the dual battery with a perko
  1. Dual Battery Install Help
    By Mritter in forum Service & Repair
    Last Post: 12-26-2007, 04:43 PM
  2. Dual battery ... where to hook the amp?
    By Burke in forum General Chat
    Last Post: 07-02-2007, 07:21 PM
  3. Dual Battery system
    By mvd in forum Service & Repair
    Last Post: 05-04-2007, 02:49 PM
  4. Dual battery setup
    By iaonbb in forum General Chat
    Last Post: 04-08-2007, 10:47 AM
  5. Boat Dual Battery Setup
    By jon_n_andrea in forum General Chat
    Last Post: 01-10-2006, 12:56 PM
