Results 1 to 6 of 6
Thread: Post your amp racks
02-25-2008, 10:31 PM #1Member
- Apr 2007
- 36
Post your amp racks
I getting ready to mount my 2 kicker amps and at 20inches long i having a real hard time finding space so far i thinking i doing the drivers side right wall and passenger side left wall.
So who has some pics?
Also my other big problem mounting an Eq in my 05 lsv can not find anything to secure it to. Found several places i want to put it but nothing above it to secure it in place
02-26-2008, 09:26 PM #2
Ive looked all over this site for pics of installs and found very few. This place is great dont get me wrong but for some things your better off using the search function on Wakeworl.com. For what its worth im also getting ready to install my amps (06 outback V) and im thinking under the drivers side behind my sub is going to be best. I dont want to loose the storage space in the passanger side so i'll just have my batteries and isolator switch in there, amps and sub on drivers side.
02-26-2008, 11:39 PM #3Junior Member
- Feb 2008
- Yakima, WA
- 17
I just finished the install in my Supra about two weeks ago -- I'm pretty sure you could do the same thing in the newer Moombas. The front is mounted flush with the hull, and is mounted using an L-shaped bracket and one of the amp screws to the fiberglass bulkhead (you can see the bracket in the last pic). The back is mounted with shallow screws that go through the top of the bulkhead (you can see the heads in one of the pictures). Just don't use too long of screws!!! I made cardboard mock-ups before putting in, to be sure it fit and to get the angles correct. The panel is made of .5" MDF coated in fiberglass resin to waterproof it. I also moved the house battery forward to open up more storage space (the stereo battery is underneath the passenger-side seat).
Cal
Yakima, WA
2007 Supra 22SSV
WashingtonWake facebook group
03-15-2009, 08:23 PM #4Member
- Jul 2006
- Austin, TX
- 38
That is a great setup! I also have 3 JL amps. Have you had trouble with them overheating at all? I have been thinking about enclosing my rack with plexiglass and using fans to blow air through them...any thoughts?
03-15-2009, 09:46 PM #5
I plan on adding another before summer. I guess I better hurry......
-McMoomba
2008 Outback V
03-15-2009, 10:45 PM #6
Check my profile under mods
Trailering: Wakeboards in Racks? or Out of Racks?
By Bulldgz in forum General ChatReplies: 12Last Post: 05-23-2007, 12:05 PM -
Where did my post go
By jwest2000 in forum Wakeboarding | WakeskatingReplies: 3Last Post: 03-28-2006, 08:43 AM -
How do I post a pic?
By tygger6069 in forum Pride & JoyReplies: 1Last Post: 10-12-2005, 12:40 AM -
How do I post a pic!!!!
By Aquaholic in forum General ChatReplies: 3Last Post: 03-24-2005, 08:31 PM
