Results 1 to 9 of 9
Thread: boat buddy?
02-10-2008, 05:13 PM #1
boat buddy?
does anyone have a boat buddy on the trailer?
if so, what size? have you had any problems? i have read a few reviews that some pine or what ever breaks or bends. i like the idea of making the loading easier.
any one use the retractable tiedowns? what size type do you have or recommend?
the factory straps seem to be quite a bit more expensive than others, and i heard that they are the same, they just don't say Moomba. i would feel bad about not saying moomba, but not too bad.
02-10-2008, 09:00 PM #2
As long as you keep the bow eye centered you are fine and it works great.
-Jay
2008 Supra 21V
02-10-2008, 10:51 PM #3
I use retractable tie downs. Not sure what size but I think they are around 2,000 lbs each.
I could not use a boat buddy very well around here due to steep ramps/low water.. when the water is real low, I have to work it on to the trailer.
BWBrad
2006 Moomba Mobius LSV sold
2004 Outback sold
02-11-2008, 12:22 AM #4
thanks for the info, this leads to another questions on the boat buddy, if i get the buddy, do i have to drive the boat all the way on or can i use the crank for the the steep ramp, shallow ramp, or what ever? what are other conditions that prevent the use of buddy. i believe it is a standard on supra.
on the tiedown strap, i guess i should have asked how long are they?
02-11-2008, 11:00 AM #5
ive had the boat buddy on the last 4 trailers
our routine is the same as Ed discribes--it makes loading a boat on the trailer a work of art
also have the rear retractable straps--there bolted to the trailer so i never forget to "put them on"
stacy
02-11-2008, 01:56 PM #6
cost
How much does this cost and how hard is it to install? I think this sound really awesome.......
02-11-2008, 02:22 PM #7
links were i got mine
http://www.basspro.com/webapp/wcs/st...004000_200-4-3
and
http://www.basspro.com/webapp/wcs/st...ID=&subcatID=0
stacy
02-11-2008, 07:40 PM #8
thanks for the info.
i picked up the tiedowns today. they only had the smaller buddy in stock. it says it is recommended for boats up to 21' the LSV is 21'6, should i be concerned? what might be different on the larger size? it is only $15 more.
02-11-2008, 09:09 PM #9Sled491 Guest
Go with the bigger one, these aren't exactely lite boats compared to other 21 or 22 ft boats
Anchor buddy
By chillyx in forum General ChatReplies: 7Last Post: 03-29-2008, 04:09 AM -
Boat Buddy latch
By bamaspiveys in forum General ChatReplies: 4Last Post: 03-09-2008, 04:16 PM -
Boat Buddy??? What is this?
By mobiusLSV05 in forum General ChatReplies: 15Last Post: 06-05-2005, 03:04 AM -
Boat Buddy for Traler
By seanpatsdad in forum General ChatReplies: 3Last Post: 02-28-2005, 01:12 PM -
ski buddy needed in Ft Myers, FL
By dewey in forum Skiing & SlalomReplies: 1Last Post: 06-10-2004, 03:26 PM
