Results 1 to 7 of 7
Thread: 03 outback info
    menomonee falls Wi
    Default 03 outback info
    I have owned a few boats over the last 30 years but never a inboard.I have 2 kids one loves to ski the other a wakeboarder. Considering to purchuse a 03 outback.Any info on this boat would be very helpfull. Thanks Kevin
    Aug 2007
    Toronto, Ontario
    I think the Moomba updated the Outback hull in 2003 and is the same as I have in my 2007. As for wakeboarding, the boat is designed for slalom, but with Gravity 1 and a tower, you have to be a pretty good wakeboarder before you 'need' a heavier V drive.
    As for slalom, it very very hard to beat.
    2007 Moomba Outback
    99.999% Slalom, 0.001% Wakeboarding
    Feb 2007
    Chicago, IL
    If possible get the EFI motor on a used Moomba. It was an option in 2003, and I would recommend it.
    Mar 2006
    Chapin, SC
    2003 was the first year of the current hull. It should have 310 or 325 horse power depending if it has EFI or Carb. What all options are listed? I have an 04, ski the course and then fill a few sacks for kneeboarding. Its a perfect wake for all of that stuff. Yeah the V drives usually offer more ballast capability etc. and are better designed for wake boarding. Eitehr way I dont think you can go wrong on an inboard. You will figure that out in a matter of days after you have one. I will have one and most likely it will always be mooma or supra until I am forced into a pontoon at 80.
    Sled491 Guest
    Depending on the ages of the kids and how much coin you are willing to put out you won't go wrong with the Outback. If you need more gadgets you can add them if you need to ie, ballast etc. What are the options being listed, how many hrs? Is this a private deal or through a dealer?
    Sep 2007
    Lake Champlain - Vermont
    check my new posting in the classified section and compare to to the deal you are considering........
    Jun 2002
    Lake Mayo NC
    Just a reminder , in that year (and maybe even now) there are 2 boats called the Outback. Outback and Outback LS, the LS is a Mobius hull, just different graphics and standard equipment. The Outback is a different hull, more optimized for skiing
  1. where is the best info for new wakesurf FAQ's
    By yearround in forum General Chat
    Last Post: 02-04-2008, 05:37 PM
  2. raw water impeller info.
    By stephane19 in forum Service & Repair
    Last Post: 01-18-2008, 10:38 AM
  3. buying boat looking for some info.
    By weeds-suck in forum General Chat
    Last Post: 09-22-2005, 11:56 AM
  4. user info
    By Yellowmobius in forum General Chat
    Last Post: 02-22-2004, 12:05 PM
  5. Inboard Boat Info
    By jburnside in forum General Chat
    Last Post: 03-24-2003, 01:49 PM
