Results 1 to 10 of 14
Thread: 325 vs. 340
01-16-2008, 04:36 PM #1Senior Member
- Mar 2006
- Chapin, SC
- 159
325 vs. 340
Anyone know if the 340 upgrade is worth it? Im considering selling my 04 Outback DD for the 08 Outback DD.
01-16-2008, 04:52 PM #2
I decided against the 340 upgrade. don't know the diference first hand, but the dealers i talked with were not able to sell me on the benefits beyond being a bit more eco-friendly. they say something about a bigger torque band?
i don't really think that would be too necessary on the outback. one did say it may be a bit more fuel efficient, but he described it as being about a 1/4 gph, probably not noticeable in the expected 5-6 gph.
don't really know other than CA emmissions, maybe someone wiht real knowledge can help?
01-16-2008, 04:54 PM #3
Depends - how much is it to upgrade?
Al
01-16-2008, 04:59 PM #4Senior Member
- Mar 2006
- Chapin, SC
- 159
On the Boat Builder section of this website, it is a $1,495.00 MSRP cost for this upgrade
01-16-2008, 05:14 PM #5Senior Member
- Oct 2007
- Panama City Florida
- 1,798
That depends if a 4.5% power increase is worth 1500 bucks? I don't think I would be able to tell it. And since Horsepower ratings can vary up to 15% from engine to engine (the only vehicle I have seen where they actually check EVERY engines hp was when I took a Porsche plant tour and saw them building each engine by hand then checking EACH engine) then that can mean the power ratings can be all over the board. I would only get it if I HAD too (California?)!
01-16-2008, 07:23 PM #6Sled491 Guest
Remeber I don't wakeboard or balast, but consider this. I'm 190lbs and ski a 66" double highwrap and my 325hp 07 Outback rips me out of the water no problems. If it were up to me I'd spend the 1600.00 on some cool options. But I've been shot down on this board before on my opinions about the 340hp upgrade
01-16-2008, 08:13 PM #7
YellowMoomba - I'm with Sled. I have an '07 Outback w/ 325. Plenty of power for anything we do behind our boat, and its a proven engine. Has performed flawless for us. - Deerfield
01-16-2008, 08:20 PM #8
I don't think the 340 is worth the extra money in the Outback. The LSV would be a different story. Its all about torque with the heavier boats and the 340 has the torque
2008 Outback
325 EFI
Gravity 1 Ballast and Multi Sport Wake Plate
Rad-a-cage
OJ 4 Blade 13x13 Prop
5 Seasons pulling the Ski Team and still going strong!
01-16-2008, 08:30 PM #9Senior Member
- Oct 2007
- 1,798
Not to disagree with anyone but torque comes from higher compression and cam profiles and of course displacement. Horsepower is a function of torque times rpm so if you can spin a certain amount of torque at a higher rpm you get more horsepower. An exhaust system has a certain back pressure and if you reduce this backpressure you are allowing the engine to breath better hence higher rpm then more horsepower (an engine is another version of an airpump). I would have to say that if this engine has higher torque then Indmar has either changed the cam profile or an injection map or both. And you also need high exhaust temps to get the CAT to light off so I would also bet that the engine is putting out higher temperatures due to a leaner mixture. It would be interesting to see the hp and torque vs. rpm graph for both engines. My other concern would be the cost of replacing the CATs especially if they are using a precious metal, I promise this will be much more than the regular exhaust system. The CATs on my BMW cost 1200 bucks each from the dealer!!!
01-16-2008, 10:36 PM #10Senior Member
- Dec 2004
- Cinci-Dayton
- 1,014
I vote definite waste on a DD. V-drive is tougher.
A friend with a Supra 22V has the 340 and it was probably a good Idea. Another friend with at 21V has the 325 and very little difference b/t the two. I’m not sure the 22V would keep up with my 05 LSV with the 325.
22’ & over I’d got 340. Otherwise, we all pull 6 kids on tubes and you cannot tell one ride from the other. The 22 empty has a very slight speed edge on my LSV on the straightaway (1-2 mph), but then, you are really racing tractors (not what they were built for).
The weight may help with surfing.
