Results 1 to 10 of 14
Thread: towing capacity
01-08-2008, 10:50 PM #1
towing capacity
So I was wondering how much weight can you tow behind a LS with the 325 ? or how many skiers do you think? Just curious, my boat should be here in a month or so and I was wondering what my limits will be?
01-08-2008, 11:00 PM #2
I've pulled as many as 4 kids and the boat didn't know it was pulling anything. I've had 2 adults on 1 ski, both over 200lbs. and there was no hesitation at all. I would not have even tried that with my old i/o. You should be able to pull about anyone you want.
07 Mobius LS--Razorback Red
01-09-2008, 11:40 AM #3Senior Member
- Oct 2007
- Panama City Florida
- 1,798
BamBam
These are serious torque machines! My wife and I had a nice 19ft boat with an Evinrude 140 on it for years. I would put the slalom ski on get in the water and tell my wife to HIT it! She would give it full throttle and then after what seemed like eternity the 2 stroke engine would finally hit its max torque and I would get up. Now we go and get the 200Hp+ MasterCraft, I jump in put the ski on and tell her to HIT it! She throws the throttle all the way down and I scream out in pain as she dislocated my middle finger on my right hand. These boats put out tremedous amounts of low end torque. I liken it to a locomotive. You just give it a little throttle and the forward motion begins. You CANNOT lean back on your ski and slow it down like I could with other boats! This nice constant pull also makes it so easy to teach begginers how to get up!
Good Luck with your new LS! I will be at the Atlanta Boat show on Saturday putting in an order for ours!
01-09-2008, 12:54 PM #4Originally Posted by zegm
01-09-2008, 01:09 PM #5
Yep, that's why I keep a tube of super-glue in the boat. To glue back on anything that gets pulled off
01-09-2008, 04:38 PM #6
LOL !!! Between his legs.
How many skiers you can pull is directly proportional to their level of skill.
I've personally witnessed 15 skiers behind an inboard.
Last year I pulled 10 with my Outback. Theres no doubt that I could have pulled more. But then again I've seen 3 people struggle to get up because the skills just weren't there.2008 Outback
325 EFI
Gravity 1 Ballast and Multi Sport Wake Plate
Rad-a-cage
OJ 4 Blade 13x13 Prop
5 Seasons pulling the Ski Team and still going strong!
01-09-2008, 04:51 PM #7
I appreciate all the replies thanks everyone..........
01-09-2008, 05:28 PM #8Member
- Nov 2004
- Bloomington MN
- 72
Where do hook all the ropes when you pull 15 people?
01-09-2008, 06:23 PM #9Senior Member
- Oct 2007
- 1,798
Ah good question, there must be some sort of bar?
01-09-2008, 11:23 PM #10
You can actually deal with multiple ropes several ways.
We usually just pull the ropes thru the end loops and put them on the pylon -- the lower the better.
For our pyramid act in the ski show we made a harness using a 3 foot length of 5/8" rope. The harness rope has a loop on both ends, all the ski rope loops are threaded onto the harness rope and then the harness rope is threaded thru its own end loop and then attached to the pylon. It works great.
My show roper (spotter) is so used to dealing with multiple ropes that it really isn't much trouble at all. If they do get tangled up, they usually pull the tangled portion up close to the pylon so it doesn't effect the skiers.2008 Outback
325 EFI
Rad-a-cage
Tow Vehicle Capacity
By brianw21 in forum Sales & InformationReplies: 20Last Post: 04-10-2022, 08:53 AM -
LSV Towing Needs
By shulaj in forum General ChatReplies: 18Last Post: 01-25-2007, 06:51 PM -
High Capacity Ballast Pump
By cab13367 in forum General ChatReplies: 8Last Post: 12-20-2006, 04:56 PM -
towing capacity
By dwike in forum General ChatReplies: 16Last Post: 11-27-2004, 08:17 PM -
Gas tank capacity
By lcwil in forum Boat OwnersReplies: 2Last Post: 06-11-2002, 04:51 PM
