Results 1 to 10 of 13
    Aug 2006
    Salt Lake City
    Default Does Perfect Pass WB Pro have a temperature gauge?>
    I thought I remembered a post about Temp on Perf Pass... I searched but could not find it.. If you look on PerfPass website, it mentions some boats have it... Looked at the downloadable instructions and see no mention?
    Just curious.. For what its worth, I have 06 LSV and the PP was factory option..
    THANKS
    BW
    Brad
    2006 Moomba Mobius LSV sold
    2004 Outback sold
    Aug 2006
    Salt Lake City
    so maybe I answered my own question now.. READ A little more carefully..
    So... Next question... Are Moombas set up for this?
    Press Menu & Up keys together to access the following:
    Screen Contrast – By pressing up or down keys you can change the contrast level.
    Range is 1 – 5. Lower values = better visibility in extreme sun. 3 is normal.
    Name List – You can get to the name list through this feature, or by highlighting the
    mode or name on main screen and press up.
    System Info – This screen will display software version #, battery voltage, engine
    selection, hour meter and water temperature. (Some information not on all boats)
    Device Test – Troubleshooting information for servo motor or electronic throttle
    systems.
    Brad
    2004 Outback sold
    Aug 2006
    Salt Lake City
    Thanks Ed.. I'll have to look and see.. whenever I see the poor, lonely boat again..
    Brad
    2004 Outback sold
    Jul 2003
    You're paddlewheel should have the temp sensor and wiring. If you check the system info and it doesn't give you a reading, the most likely culprit is the fact that they just didn't hook it up. I have an '06 that was like that and found that is was as simple as just plugging the wiring harnesses together. Everything was wired and ready to go, but for some reason they just didn't plug it in. I've heard from other people who have had the exact same problem.
    Aug 2004
    Lake Hickory, North Carolina
    Heck, just stick yer toe in the water.........if it feels cold, it prolly IS cold.
    Hope this helps
    :P
    B
    Learn all you can today. Tomorrow you may need to know it!
    2004 Moomba Outback. Tower Speakers, amp, ballast, ssrr ... she's a cutie!
    Oct 2005
    Ha.. some of us would never ride then . I normally see low 50's in middle May and high 60's as the warmest for the season. The temp indication is a good tool.
    This topic has come up before. My '05 came with a manual that has instructions on how to get temp, how to calibrate it, etc. In later versions, some of this was left out for some reason.
    Your boat should have this feature. I think it's an extra wire or two out of the paddle wheel. I don't think you need to be in the water to get an indication.
    Sled491 Guest
    It's on my 07 PP, but not real easy to use. If you go to the screen with the temp you loose all your other info like speed and tach. So its good for a quick check, but not real good for continuous use unless you don't want the other normal features.
    Oct 2005
    Yea, there is no reason to display it all the time. I know how warm it needs to be before the kids or I can shed the wetsuit. It helps with that. Butta's method works too. But, it's nice to have. Especially when your friend with an I/O has it .
    Aug 2004
    It is a nice feature. Unfortunately, I don't have PP. Mebe some day.
    I'm on the boat by mid April, but not usually in the water until Memorial Day weekend or somewhere pretty close. By then the water has warmed up to a tolerable level.
    B
    Default Re: Does Perfect Pass WB Pro have a temperature gauge?>
    Quote Originally Posted by 04OUTBACK
    THANKS
    BW
    That post was from me. Below is the link. I have the same boat as you.
    https://forum.moomba.com/viewtopic.p...512&highlight=
Similar Threads
  1. What Size is the Gauge??I am ordering Perfect Pass
    By wake08 in forum General Chat
    Last Post: 03-04-2008, 08:37 PM
  2. How do I remove Perfect Pass gauge
    By spyder in forum Service & Repair
    Last Post: 10-10-2007, 07:45 PM
  3. Temperature Gauge
    By Waynes345 in forum Service & Repair
    Last Post: 06-22-2007, 11:53 AM
  4. Perfect Pass Temperature Calibration
    By Shoemaker Mobius in forum Service & Repair
    Last Post: 05-18-2004, 10:01 AM
  5. Where to put perfect pass gauge?
    By Preston Duke in forum General Chat
    Last Post: 01-19-2003, 07:32 PM
