Results 1 to 10 of 13
Thread: steering cable replacement
12-26-2007, 09:32 AM #1Senior Member
- Aug 2002
- Bismarck, NorthDakota
- 579
Has anyone one replaced a steering cable on a 2004 LSV? I am going to run my LSV one more year. Last season the steering was gradually getting harder so I will be replacing the cable. I haven't decided if this is something I want to do myself or take it to the dealer.
Bruce Fuerstenberg
12-26-2007, 12:24 PM #2Senior Member
- Oct 2005
- 199
It'll cost more at the dealer. I changed mine in '06; here is the post:
https://forum.moomba.com/viewtopic.p...248&highlight=
There are some photos in my webshots maintenance folder below. I recall the guy with a red '02 or '04 LSV (Jesse) has posted on this with some good pictures as well. I think the secret is to keep the rudder end full of grease, so water doesn't get in there. Once you take it apart, you'll know what I'm talking about. Good luck.
12-26-2007, 08:25 PM #3
Here is the thread where I inserted some pictures. There are comments on what I ran into. All in all it was a really easy job.
https://forum.moomba.com/viewtopic.p...406&highlight=15 Mondo Surf Edition
02 LSV - Traded In
01-01-2008, 09:48 AM #4Senior Member
- Dec 2006
- tally, fl
- 283
Jesse I think building the space shuttle would've been easy for you have a Very Happy New Year and thanks again for all your help! bob
01-01-2008, 07:44 PM #5Senior Member
- Oct 2007
- Panama City Florida
- 1,798
I am wondering why and how a steering cable could be worn out after 2 years. I have the original in the 1975 MasterCraft. I am sure it is a Teleflex or Morris cable. I would suspect incorrect routing???
01-01-2008, 08:09 PM #6Originally Posted by zegm
The newer LSV models havethe modified cables in them.
Note for replacement: Just make sure you get all of the screws out of the floor. There are about 6 of them inside each of the "seating" holes where the cushions go. Do not force the floor up, it is very easy to lift free. If you miss any screws, you are gonna have issues putting the floor back and it not rattling or creaking. This is a very easy task15 Mondo Surf Edition
02 LSV - Traded In
01-01-2008, 09:54 PM #7
My brother has an 05 Supra Launch 21 DD. Very nice boat, but he's had steering issues since the 2nd season. He was told by the folks at SC that bilge water collected around the stern end of the cable and corroded it. They changed the cable under warranty and he still had an issue with hard steering. It was finally determined that the rudder shaft fitting in the hull had become elongated and egg shaped. Just something to check while your changing that cable. It might save you from taking it apart again.
Good luck2008 Outback
325 EFI
Gravity 1 Ballast and Multi Sport Wake Plate
Rad-a-cage
OJ 4 Blade 13x13 Prop
5 Seasons pulling the Ski Team and still going strong!
01-01-2008, 11:50 PM #8Senior Member
- Oct 2007
- 1,798
Now I am a little concerned. I have no problems with a 32 year old cable that sits in a bath of water almost all summer. I have had to replace the rudder port due to it being worn out after years of usage but the cable still looks fine. I hope this is not an issue of poor "Chinese" material??? With the he last 2 Silverados I owned the cables broke on the tailgate after a couple of years. I noticed when I purchase a new one from the dealer a sticker on it "made in China"! Could it be that Teleflex which now owns Morse cables too has a factory there (if these are Teleflex)????
01-09-2008, 11:31 PM #9
I'm not sure who makes the Moomba/Supra steering cables. But in my experience, changing out the steering cable every few years is just normal maintenance. I replaced the cable in my Nautique and about everyone I know that has a boat older than 5 years old has replaced one.
It would appear from the post in here that you should expect to change it from time to time if your planning on keeping your new Moomba for 25 years2008 Outback
325 EFI
Rad-a-cage
01-09-2008, 11:52 PM #10Senior Member
- Oct 2007
- 1,798
When I replaced the rudder port I checked the cable and it was fine! It could be that these heavier boats take more force to turn and this could cause the wear. And according to my wife the household banker we will be keeping it for 25 years!
Steering Cable Problem with 03 Outback - Replacement Help?
By moneytonoise in forum Service & RepairReplies: 2Last Post: 06-29-2011, 04:08 PM -
Steering cable
By seanpatsdad in forum Service & RepairReplies: 3Last Post: 04-08-2008, 03:50 PM -
Steering Cable / 2004 XLV GG
By TobesDubai in forum Service & RepairReplies: 3Last Post: 01-10-2007, 02:01 PM -
Steering cable replaced
By MEDIC151 in forum Service & RepairReplies: 0Last Post: 06-25-2004, 11:00 AM -
Steering Cable
By MEDIC151 in forum General ChatReplies: 3Last Post: 05-16-2004, 08:31 PM
