Results 1 to 3 of 3
10-25-2007, 11:37 PM #1Junior Member
- Oct 2007
- Malvern
- 1
Steering Cable Problem with 03 Outback - Replacement Help?
The steering is getting very hard so I think I need to replace the cable. How do you remove the flooring to get to the cable? Any advice and pictures spcific to this model would be appriciated. I read one post that said they had to enlarge the hole where the cable passes through the floor in front of the driver seat. I don't care to cut any fiberglass.
Has anyone had luck getting this problem covered under warranty on a 4 year old boat?
Sound like there needs to be a better cable that won't corrode and or a more convient way to access the end of the cable to keep it greased.
My boat does not have a depth gauge, so I thought I would install a through the hull transducer while the floor panels are out. Can any one recomend a location specific to this boat?
04-01-2011, 11:06 PM #2Junior Member
- Apr 2010
- Frisco, TX
- 11
Did you ever figure out how to do this? I have an 03 outback and will be doing this tomorrow. Any pointers would help! thanks
06-29-2011, 04:08 PM #3Member
- Apr 2010
- moncton, nb canada
- 60
Is it a DD or V-Drive, I just had problem with mine. I have a 03' Outback LSV. You remove all the screws on your floor, remove all seating and lift floor from the rear and slide back. Really easy and not heavy. 2 person job. I removed my cable as the rudder was moving freely and the steering too. Unhooked the cable from the rudder, unbolt 4 bolt holding the cable down, pull the cable from under driver's footwell, once you noticed that the cable is half way mid tank, tie a rope so you can fish the new one. When I removed mine I noticed that the cable was not the problem but the sleeve before the rudder was seized on the cable. I yanked it hook with a hammer and punch and the sleeve slide out. Cleaned everything and grease everything. Now working perfectly and returning the new cable back to dealer i bought it from. Just be sure its seized inside not in the sleeve. Might save you some money. The whole replacing thing should take you about 1 1/2 hour to 2. Its a 2 person job to make everything easy.
Steering cable
By seanpatsdad in forum Service & RepairReplies: 3Last Post: 04-08-2008, 03:50 PM -
steering cable replacement
By Yellowmobius in forum Service & RepairReplies: 12Last Post: 01-17-2008, 04:16 AM -
Replacing steering cable on 02' Outback.
By barefooterh2o in forum Service & RepairReplies: 1Last Post: 10-06-2006, 07:55 PM -
Steering Cable for '03 Outback LSV
By in forum Service & RepairReplies: 11Last Post: 02-08-2006, 03:38 PM -
Steering cable on outback
By quincy in forum General ChatReplies: 6Last Post: 08-06-2005, 02:21 PM
