10-23-2007, 08:28 PM #1Junior Member
- Oct 2007
- 3
Advice for 2001 Mobius Winterization
Planning my first winterization and need some help for my Mobius (Inboard, EFI):
Oil Filter (Fram 30?)
Oil type & capacity w/ filter change (Sounds like the recommended oil is Delo 15W40...?)
Fuel filter was changed last year....should I? Where and what type?
Impeller (Is it the same one as discussed in the other posts?)
Rear seat factory Ballast - just drain the hoses, bag, and unscrew the top of intake pump?
Fog the motor? Procedures? I've got the spray can stuff for my 2-stroke snowmobiles...will this work?
Free Cold Beer and venison sausage if near Madison, WI and can help!
Also, my buddy's 93 Mastercraft has a garden hose connection for on-shore maintenance....does anybody know if Moombas have this? If not, could this be fashioned/installed? Which hose? Or should I just drag it to the landing and warm up, change the oil, and restart there before coming home to drain the water hoses?
Thanks for the help in advance?
10-23-2007, 08:59 PM #2Senior Member
- Jun 2007
- Calgary Alta Canada
- 926
As for garden hose connection I ordered the flush kit option on my 07 Outback and it works real nice Probably could be purchased separately and added in without too much trouble.It has a checkvalve assembly built in as well.
10-23-2007, 09:15 PM #3Junior Member
- Oct 2007
- 3
Thanks! Which hose is the flush kit mounted on?
10-23-2007, 10:42 PM #4Senior Member
- Jun 2006
- 194
The raw water intake hose.
98 Mobius Ballast - Advice
By 98mobiusbda in forum Wakeboarding | WakeskatingReplies: 0Last Post: 06-26-2006, 01:14 PM -
2000 Mobius Buying Advice
By BigRed in forum Boat OwnersReplies: 1Last Post: 11-13-2003, 10:44 PM -
By BigRed in forum Sales & InformationReplies: 2Last Post: 11-11-2003, 12:44 PM -
2001 Mobius
By Granite Mobius in forum General ChatReplies: 3Last Post: 07-09-2003, 01:00 PM -
2001 Mobius
By alpaca in forum Service & RepairReplies: 4Last Post: 06-20-2003, 10:34 PM
