Results 1 to 10 of 10
Thread: any tips
10-22-2007, 02:05 PM #1Member
- Oct 2007
- chicago
- 43
any tips
first time inboard owner (07 mobius lsv) and was wondering any tips/tricks/regular maintenace to perform on the boat other than the regularities?? any recommendations from fellow moomba owners?
10-22-2007, 03:53 PM #2Member
- Jun 2007
- 74
check your fluids everytime before you go out.... and enjoy it
10-22-2007, 07:35 PM #3Senior Member
- Dec 2004
- Cinci-Dayton
- 1,014
Basspro sells a plug with a whole in the end for inserting a screwdriver and turning. Get one, run a line so it can hang on the throttle. When you pull out, tie the kill switch to it if you are really forgetful.
Aero 303
check all the tower bolts at least twice a summer.
sd2
10-22-2007, 07:58 PM #4
SMOKEDOG - what is the point behind this plug tied to the kill switch??
10-22-2007, 08:06 PM #5
Get rear tiedown straps and use them. Cheap insurance. But remember to take them off before dropping in. Your boat will not start on the launch if it is secured to the trailer at the back due to back pressure on the exhaust flaps.
No shoes in the boat, not even sandals or flip flops.
Turn the motor off when people are near the boat in the water.
Don't do stupid sh#t.
Whenever you take the boat out of the water pull the drain plug.
When sitting unused for multiple days, prop the motor cover open (for direct drive) to reduce corrosion under clamshell.If you believe something to be true, it will be - in it's consequences.
10-22-2007, 08:38 PM #6
Liquid: Practice maneuvering at slow speeds 5 mph or less, these boats handle a lot different than I/Os.
Check the ballest before loading even if you didn't use it sometimes the bags fill on their own.
Also if you haven't tried it, use vineger and water 1 part to 10 for cleaning some of the tougher water spots etc. It's cheap n easy.
Have fun and welcome to the Moomba clan!
10-22-2007, 09:04 PM #7Member
- Oct 2007
- chicago
- 43
ya ive grown up with a boat, on boats, and around boats so i know alot. ive driven other inboards and they do handle completely different (still learning how to dock it!) i was just asking for tips on fluids, checking things like the bolts and engine gears, regular maintenance, ect....keep the tips coming guys! thanks for everything...i just wanna make sure to keep this slice of heaven perfect for as long as i can.
10-23-2007, 01:42 PM #8
Grease cable ends yearly, check your cleats regularly if you raft up often, keep an eye on your swim platform mounting hardware. Do not leave a cd in the cd player while boat is stored.
B
Oh yeah, pray for a short winter
10-23-2007, 07:08 PM #9Senior Member
- Oct 2005
- Central FL
- 791
Good wax job yearly or more
303 protectant every other wash
Marine Spray Nine for anything that needs real cleaning, mild soap and water for everything else.
Change the Impeller yearly (I know you already know this, but anyone reading it can always see it again.
Don't tow tubers or skiers from the tower.
Invest in a cover cover (yes, meant twice) if you keep the boat outside.
Enjoy every time you get her out!
-Joe
10-23-2007, 09:46 PM #10
Change the tranny fluid each year and put in exactly the amount you take out. You need to suck out as much tranny fluid as you can and replace with the like amount. Too much or too little is not good for the tranny.
Resources for Slalom tips
By BensonWdby in forum Skiing & SlalomReplies: 18Last Post: 11-20-2008, 12:34 PM -
FAE install tips?
By tlatoani in forum General ChatReplies: 2Last Post: 04-30-2008, 09:24 PM -
V-Drive tips
By Yellowmobius in forum General ChatReplies: 3Last Post: 05-07-2005, 08:00 PM -
Tips to get begginers up
By Livindadream in forum Skiing & SlalomReplies: 8Last Post: 10-12-2004, 05:28 PM -
Oil Change tips
By dburroug in forum Service & RepairReplies: 4Last Post: 07-21-2003, 10:21 PM
