Results 1 to 8 of 8
Thread: New Engine
10-21-2007, 01:55 PM #1Member
- Nov 2006
- 39
New Engine
Would any body know if it's possible to fit a MX 6.2 Black Scorpion - 340 hp engine into a 2004 Moomba XLV GG..??
Look forward to hearing your thoughts!
10-22-2007, 02:47 AM #2Senior Member
- Jul 2003
- 340
Would it fit? I'm guessing yes it could be made to work but the real question is why. I can't see the benefits being worth the effort. If you're looking for more power you'll be a lot better off playing around with different props.
10-22-2007, 07:38 AM #3Member
- Nov 2006
- 39
New Engine
Sadly it's not a case of extra power, the oil sump corroded and she dumped all her oil whilst running and the result is a bent crank shaft and damaged pistons.
A rebuild in Dubai is sadly not an option as no one will commit to it. The only reason for the Scorpion is that the Mercruiser dealer has one in stock and it could be fitted very quickly.
10-22-2007, 11:29 AM #4Member
- Jun 2007
- 74
go with a yanmar deisel..... better fuel consumption and low end torque and it should mate just fine with the v drive tranny
10-22-2007, 01:57 PM #5Member
- Nov 2006
- 39
New Engine
Is a Yanmar really an option??
Diesel Ski Boat, its going to sound terrible..!!
Has anyone seen this done??
10-22-2007, 03:52 PM #6Member
- Jun 2007
- 74
go to wakeworld and do a search on it... its a very awsome option. and they last forever.... thousands of joyful hours
10-23-2007, 01:50 PM #7
Yes, I believe it is an option.
10-23-2007, 10:09 PM #8Sled491 Guest
Wow, that sounds awsum, a deisel ski boat...too cool. Oh by the way to bad about your motor, at least it's the end of the season...I hope?
Which engine do I go with?
By ucandoit in forum General ChatReplies: 16Last Post: 07-04-2007, 03:43 PM -
Engine ID: 325 vs 340 HP MPI
By Ian Brantford in forum Sales & InformationReplies: 9Last Post: 05-31-2005, 02:36 PM -
Engine Oil
By MartyC in forum Service & RepairReplies: 21Last Post: 05-15-2004, 09:04 PM -
Engine bog down
By Yellowmobius in forum General ChatReplies: 2Last Post: 07-28-2003, 02:45 PM -
engine
By jqrk in forum Service & RepairReplies: 5Last Post: 07-22-2003, 03:21 PM
