Results 1 to 10 of 12
Thread: Noisy when pulling a boarder
10-15-2007, 09:57 PM #1Junior Member
- Oct 2007
- 21
In my 06 LSV, the transimission/vdrive it overly noisy when pulling up a boarder. Especially when their is a lot of weight in the boat and/or the ballast are full. My buddy's 07 LSV, is much quieter. Is this something I need to be concerned about?
10-16-2007, 08:52 AM #2Senior Member
- Jun 2007
- 883
Check the fluid levels? or do you need to replace the fluid?
2006 Moomba Mobius LSV
Stereo: Kenwood KMR-D562BT
Ballast: 750 Surfside locker, 400 Surfside mid boat, 400 Gravity I, 400 Bow
Surfboards: Inland Surfer Red Woody, Triple X Composite X 58"[/SIZE]
10-16-2007, 09:43 AM #3
I too experience what you are talking about.. I have checked my fluids...
I suspect it may have to do with motor alignment.. let me know if you figure something out.
BWBrad
2006 Moomba Mobius LSV sold
2004 Outback sold
10-17-2007, 09:05 PM #4Junior Member
- Oct 2007
- 21
I checked the fluids, but everything looks ok. Not sure what else to try. Thanks for your suggestion.
10-21-2007, 11:17 PM #5
What prop are you guys running on your LSV's? Suprisingly I've noticed a huge difference in sound from the stock prop to the wakeboard prop. I think there's something about the angle of the wash hitting the boat or something of the sort. It almost sounds like something is going on at the engine/transmission but its not. It gets worse the more ballast and is at is worst when fully accelerating right after you put it in gear. It seems to clear up before you get to wakeboarding speed. I got used to it after a while.
10-22-2007, 08:09 AM #6
I have Factory upgrade wakeboard prop. I hope that is all it is.. The guy I bought it from said his buddies '07 LSV did the same thing. I was afraid it was something else like engine/shaft alignment.
Thanks Jon.Brad
2004 Outback sold
10-22-2007, 09:55 PM #7Junior Member
- Oct 2007
- 21
I think Jon is right on the money. I switched to a wakeboard prop this year and have the same symptoms as Jon described. I couldn't convince myself that a prop could cause the noise, but now I feel better about it. Thanks Jon. I personally have not seen much performance difference using the wakeboard prop, except lower top end. I may go back to the stock prop next summer. Thoughts?
01-14-2008, 12:06 PM #8Senior Member
- Aug 2007
- Nashville, TN
- 257
could it be the wakeplate?
I have no idea, I don't even have a wakeplate on my boat, but another poster mentioned his boat was much noiser with the wakeplate up because he thought it directed the exhuast up into the swim platform instead of down into the water. When boarding, maybe you have your wakeplate up and it is noiser? I have no idea, but worth a thought. I can't imagine why it would get noiser from a 325 hp engine pulling a wakeboarder.
01-14-2008, 05:05 PM #9
To offer some perspective, my 2006 LSV with the 325 HP Indmar Assault does not produce any more drivetrain noise when pulling up wakeboarders, skiers, tubers, or surfers, regardless of the position of the wakeplate or amount of water in the ballasts or people in the boat than with a light load, at least not that I have noticed. I have the stock 4 blade prop and Gravity III ballast (950lbs).
However, there is definitely more drivetrain noise when operating in reverse which the dealer said is normal. Does everyone's boat do the same thing?
(Sorry to hijack the thread)
AlAl
01-14-2008, 05:10 PM #10
Yes, every inboard (V Drive or DD) I've ever been in makes a whining sound when in reverse. I was concerned at first, but I've probably been in a half dozen this past year, and they all make the same sound.
Noisy Fuel Pump?
By pcm2a in forum Service & RepairReplies: 0Last Post: 07-26-2007, 09:10 AM -
Pulling Power
By Longshore in forum Boat OwnersReplies: 15Last Post: 08-05-2006, 10:17 AM -
wakeboard pulling
By drewdwn in forum General ChatReplies: 2Last Post: 07-03-2006, 11:50 AM -
Pulling the boat
By AZ_Calling in forum General ChatReplies: 9Last Post: 04-23-2006, 02:40 PM -
Pulling
By drewdwn in forum General ChatReplies: 8Last Post: 03-29-2006, 12:16 AM
