Results 1 to 9 of 9
Thread: Gelcoat Finish
    Oct 2007
    Default Gelcoat Finish
    The finish on my 2006 LSV looks like new on most of the boat, but on the sides near the back just below the rub rail, the finish appears to be 'drying out' for lack of better words. You can see what looks like waterspots. It is the same on both sides. Any suggestions? How can I tell if it is the finish or just needs a nice cleaning and wax job.
    Sep 2006
    Ottawa and Dunchurch Area
    Could it be the bumpers rubbing??
    Aug 2004
    Lake Hickory, North Carolina
    I'd like to 'wheel' my '04 out over the winter. Does anyone have a methodology, like low speed buffer and a particular kind of paste?
    B
    Oct 2005
    I have a few scratches I want to get rid off. I've collected some info but have not put it to use yet:
    http://continuouswave.com/ubb/Forum3/HTML/004078.html
    http://www.carcraft.com/howto/926/index.html
    http://www.wakeworld.com/MB/Discus/m...21/282492.html
    Aug 2004
    Interesting reading. I think I have a plan.
    B
    Jul 2007
    Leesburg, Indiana
    Butta,
    I had a few scratches on my Outback. A light rubbing compound and a foam pad on a buffer takes them right out. Just don't buff too long in one spot............heat is the enemy and a buffer can burn thru gelcoat or leave a burn mark.
    No buffing for me this fall. I traded my 07 for an 08. Now the only problem I have is what colors to order.......
    2008 Outback
    325 EFI
    Gravity 1 Ballast and Multi Sport Wake Plate
    Rad-a-cage
    OJ 4 Blade 13x13 Prop
    5 Seasons pulling the Ski Team and still going strong!
    Aug 2004
    Thanks for the input M&M..I'll keep it in mind.
    B
    Feb 2008
    Houston, TX
    To the OP (and every one else) Gel Gloss is your friend. I would much rather use this on gel coat than any wax.
    I've been able to find it most places that sell a variety of cleaning supplies (Wal-Mart comes to mind) or order online at gel-gloss.com.
    I use it on my fiberglass showers occassionally and the finish lasts quite a long time (a couple years) and makes cleaning much easier. On gel coated boats it does a phenomenal job of giving it a good shine and protecting it from sun, stains, etc. Depending on how much time you spend in the water, you will have to apply more often, but with normal use, once/season should be sufficient.
    Note that it will make gel coat quite slippery, especially at first, so use with caution on any areas of your boat where people are prone to slip already (although most modern boats have non-skid surfaces everywhere you would need them anyway).
    -ryan
    '10 Wakesetter LSV
    Sled491 Guest
    I used to use Gel Gloss on my black shower in my first house, worked well at removing water spots and such, and as stated was very slippery after. But I didn't find it lasting all that long. I've also never heard of it being used on a boat but I don't see why it wouldn't. You can get it at Home Depot in the plumbing dept.
  1. Gelcoat cracks
    By moomba_armada in forum Service & Repair
    Last Post: 09-13-2007, 06:45 AM
  2. Gelcoat cracking
    By weirdo0521 in forum Service & Repair
    Last Post: 08-18-2007, 08:41 PM
  3. Finish Maintenance
    By mobiusLSV05 in forum Boat Owners
    Last Post: 08-23-2005, 12:17 PM
  4. Cracks in gelcoat
    By Miltona Moomba in forum Service & Repair
    Last Post: 06-23-2005, 01:26 PM
  5. Boat Finish
    By cham783 in forum General Chat
    Last Post: 08-18-2003, 01:47 PM
