Results 1 to 10 of 15
10-09-2007, 08:20 PM #1Senior Member
- Jun 2007
- 883
Fuel Filter replacement for a Mobius LSV
Does anyone have the part number for the Fuel Filter on a 2006 Mobius LSV? The numbers are on the bottom and I cant read it without removing the filter, and I don't want to take the filter off until I can ensure a local store has the part..
Looking for a part number or any sort of reference.
Thanks2006 Moomba Mobius LSV
Stereo: Kenwood KMR-D562BT
Ballast: 750 Surfside locker, 400 Surfside mid boat, 400 Gravity I, 400 Bow
Surfboards: Inland Surfer Red Woody, Triple X Composite X 58"[/SIZE]
10-09-2007, 08:30 PM #2Senior Member
- Jun 2007
- 883
Also do you have do unhook the battery or any other advice prior to removing the filter. Do you have to worry about getting air in the line?
10-09-2007, 09:40 PM #3Senior Member
- Jun 2006
- 194
On my LS I just put a c clamp on the hose on either side of the filter and take the filter to a local auto parts store. From memory I think it's 3/8".
10-09-2007, 09:55 PM #4Senior Member
- Jun 2007
- 883
I just found in another post for an 06 LS that the fuel filter is
The fuel filter is a Carquest brand #86299, or Wix # 33299.
This looks to be the one....
Part Number: 33299
UPC Number: 765809332997
Principal Application: GMC Motorhomes V-8 454 Eng. (89-91)
All Applications
Style: Fuel (Complete In-Line) Filter
Service: Fuel
Height: 4.352
Outer Diameter Top: 1.729
Outer Diameter Bottom: Closed
Max Flow Rate: 1-2 GPM
Nominal Micron Rating: 102006 Moomba Mobius LSV
10-09-2007, 10:16 PM #5Senior Member
- Jun 2006
- 194
That is exactly what mine looks like.
10-09-2007, 11:00 PM #6Senior Member
- Mar 2005
- t-town
- 718
that looks like the filter.
when i took it to a auto part store they about freaked at how large the in and out hose lines were. but they were able to cross reference it.
10-10-2007, 08:57 AM #7Senior Member
- Jun 2007
- 883
awesome, looks to be about $11.95CAD at carquest.
10-10-2007, 01:40 PM #8
They also carry a FRAM model at walmart. It is a larger diameter filter with 3/8 inlet and outlet. It can't hurt to have more filter media as long as you have the clearance for it. My 02 had the larger filter which does not look like the one pictured. It is smooth on the sided without the "Crimp" in the middle. That looks like a small filter in the pic.
I personally have been using a Hastings filter -
Check these for larger options:
Hastings - GF112
Descriptions : In-Line Fuel Filter
Fits : 1984 Chevrolet Corvette
Replaces : GMC 25055066
O.D. : 2 9/32 (57.9)
Inlet : 3/8
Outlet : 3/8
Length : 5 1/4 (133.4)
The FRAM one:
Part Number G3870
Product Type In-Line Gasoline Filter
Product Height 5.59"
Product I.D. 3/8 Tube Connector
Product O.D. 2.17"
Style Code 112
Pop Code D
15 Mondo Surf Edition
02 LSV - Traded In
10-10-2007, 02:14 PM #9Senior Member
- Jun 2007
- 883
I want a fancy one with clear sides so you can see if its dirty or not....
boo to these ugly ones!2006 Moomba Mobius LSV
10-10-2007, 03:38 PM #10
You can use one of the clear ones. As a matter of fact, if so inclined, you can change hose diameters and put the one of your wildest fantasies in place.
As long as the flow rate is maintained, should be ok.
Hope this helps
B
Mobius V 2000 Fuel Filter?
By wolfstone in forum Service & RepairReplies: 3Last Post: 03-17-2008, 06:46 PM -
Fuel Filter?? Lack of power on fuel throttle
By slalomskier in forum Service & RepairReplies: 8Last Post: 08-02-2007, 03:52 AM -
replace fuel filter with fuel water separator
By vansolo in forum Service & RepairReplies: 4Last Post: 05-04-2007, 12:17 AM -
Fuel Filter
By ezreitter in forum Service & RepairReplies: 1Last Post: 05-29-2004, 05:03 AM -
Fuel Filter
By natedogg in forum General ChatReplies: 4Last Post: 06-26-2003, 11:20 PM
