Results 1 to 9 of 9
Thread: Won't reach top speed
10-08-2007, 08:43 AM #1
Just for the heck of it, I took the boat out on Sat w/ no intention of riding. I thought I'd just go play around. Much to my surprise, the boat would only reach about 4000 RPM's or 35 MPH. With the throttle wide open, it would reach make a loud knocking sound, and it sounded like it was really struggling. The weird thing is that it went from 0-30 just like it always does. I took it out of gear, and it would rev to 5000+ with no load, but if I went from idle to WOT in neutral, it would knock at the higher RPM's. I spent a ton of time this weekend entertaining at idle speeds going through the canals around here, and it ran fine doing that.
The boat is a 2000 OB with the 310 HP carbureted 350. I didn't use it much in Sept, so I think some of the fuel in there was a least 6 weeks old. I'm thinking that may be the issue. I put some StaBil in it, so the fuel won't get any worse. Does anyone have any other ideas?
Thanks in advance.
10-08-2007, 12:06 PM #2Senior Member
- Dec 2004
- Cinci-Dayton
- 1,014
I think perfectpass can cut a little off the top end. How long have you had the boat? I don't think I ever hit 5000 on the water 4100- 4500 is top end I think, is the speedometer calibrated?
10-08-2007, 02:05 PM #3Senior Member
- Aug 2006
- Millington TN
- 204
Re: Won't reach top speed
Originally Posted by dtlaine
Engine NutLarry Engelbert
Indmar Marine Engines
"Power to the Sport"
10-08-2007, 10:10 PM #4
I don't think it's a prop issue. It is simply not running like it usually does. The speedos are calibrated. Maybe it doesn't normally turn 5000 RPM's, but it definitely normally turns more than 4000. I've run it at WOT for a while across the lake, and it normally doesn't make the popping or knocking noises it was on Saturday.
It does not have Perfect Pass, either. It just felt like it couldn't pull the higher RPM's under load. I'll give it another run tomorrow, and I'll see how it does. Luckily, I live on the lake, so it's no big deal to take it out for a run or two. By the time I get through the canals, it's running at 160 degrees, and it's ready to pull.
Thanks for the responses. If anyone else thinks of anything, let me know.
10-09-2007, 08:35 AM #5Senior Member
- Mar 2005
- t-town
- 718
when was the fuel filter replaced.
on my 05 supra ssv 22, boat ran great till about 3500 rpm's. if i went over that it heistated and ran really rough.
took the fuel filter out and it full of junk.
replaced and ran like a champ.
10-09-2007, 08:48 AM #6Senior Member
- Jun 2007
- 883
Originally Posted by qb122006 Moomba Mobius LSV
Stereo: Kenwood KMR-D562BT
Ballast: 750 Surfside locker, 400 Surfside mid boat, 400 Gravity I, 400 Bow
Surfboards: Inland Surfer Red Woody, Triple X Composite X 58"[/SIZE]
10-09-2007, 08:59 AM #7Senior Member
- Mar 2005
- t-town
- 718
my 325 hp ran great until a 4th of july trip to the lake. filled up with gas on the water and the problems started then.
it is a very simple check.
10-09-2007, 05:33 PM #8
Mine was replaced this summer, but I'll definitely check it out. What do most people do about the fuel/water separater? I thought I've read that some people bypass it. I'd be concerned to do that unless someone with an awful lot of credibility advised me. My boat sits at my dock, and even though it's usually covered, I can't help but think maybe water is getting in somehow. I mean, air has to get it to replace the fuel as it's burned, so there's an inlet somewhere.
Thanks again,
Don Laine
10-10-2007, 04:52 AM #9
I believe the vent is in the gas cap.
B
more top end speed?
By bamaspiveys in forum Boat OwnersReplies: 24Last Post: 02-25-2008, 04:50 PM -
Top Speed
By AZHeet in forum General ChatReplies: 10Last Post: 09-05-2006, 01:29 PM -
Top end speed
By bbow270 in forum Moomba ClassifiedsReplies: 5Last Post: 11-24-2005, 11:15 AM -
Top end speed
By bbow270 in forum Moomba ClassifiedsReplies: 4Last Post: 10-12-2005, 10:02 AM -
Speed
By Jmo in forum Boat OwnersReplies: 1Last Post: 03-03-2003, 10:16 PM
