Thread: Carb vs EFI
09-02-2007, 08:49 AM #1Junior Member
- Aug 2007
- 13
Carb vs EFI
Is there anytihng to worry about with the 310 hp carb motor over the 325 hp EFI (besides the 15hp)?
09-02-2007, 11:45 AM #2
If you're a gearhead, nope, nothing to worry about.
Actually, you don't have to be a gearhead, just follow a couple simple rules, i.e., pump the throttle a couple times to set the choke b4 starting and give an extra min to warm up.
Me '04 OB has 225 hrs on it and the carburated engine has been flawless.
B
09-04-2007, 12:39 PM #3Junior Member
- Oct 2006
- Mississauga Canada
- 11
I have just over 400 hrs on my 01 Mobius carburated engine. Starts and runs like a charm, just a quick half throttle and back before I turn the key and it fires up from cold everytime.
01 Mobius
09-04-2007, 06:57 PM #4
I really enjoyed my carb 310 on my 04 Outback.. Just switched to an LSV with EFI... Great so far, but I miss the simplicity of the Carb model.. no real electronics around the engine.. Also, the Drive by wire on the EFI seems to make throttle control a bit more difficult... Glad I got Perf Pass!
I never had any cranking issues on my Carb.. ONLY issue I ever had was if i idled through a no wake zone for a long time and then cut off, it seemed to slightly flood a little at restart, but always cranked...
If you like doing your own engine maintenance, Carb is a touch easier!Brad
2006 Moomba Mobius LSV sold
2004 Outback sold
09-04-2007, 11:37 PM #5Brian Raymond Guest
The above statements are correct. To ensure long lasting reliability and minimal running issues, be sure to stabilize the fuel in the tank, and run for a bit when winterizing. Brian Raymond
5.7 Engine with Carb
By toelke4286 in forum Service & RepairReplies: 14Last Post: 04-23-2008, 09:52 AM -
Carb????
By smoothie in forum Service & RepairReplies: 7Last Post: 08-25-2007, 10:48 AM -
Carb Adjustment
By mattjj23 in forum General ChatReplies: 20Last Post: 08-12-2006, 10:07 AM -
Upgrading Carb 310 to EFI
By Smrtz in forum Service & RepairReplies: 0Last Post: 03-03-2006, 12:09 PM -
New Carb Engine Just Doesn't Run Right
By in forum Boat OwnersReplies: 0Last Post: 05-30-2002, 04:44 PM
