Thread: White smoke
    Oct 2002
    Ontario
    Default White smoke
    I have a 2002 Outback with a Carb 310hp.
    Once in awhile when i start I get white smoke/steam out the exhaust. It only happens on start up and not while running. The temp guage never exceeds 180.
    Some times when starting after the engine is hot, It wont start until I advance the throttle, give it a little gas.
    Are these oberservations normal or is there something I can do?
    THanks for any input.
    2002 Outback 5.7 carb
    Apr 2003
    Powhatan, VA
    We have the carb set-up. Same as yours, sometimes requires a little bit of throttle manipulation on hot restarts. Usually happens when is sits for a while hot before the restart.
    Probably its carb getting hot from the engine and getting a bit of vapor lock.
    Haven't experienced the white smoke situation.
    Jan 2003
    Minnesota and Wisconsin
    Default Cold Start needed when hot
    We have a 99 Mobius with Carb 310 HP. I have gotten in the habit of cold starting it when hot becuase it was needing that about half the time. Never spent much time thinking about it. My old Johnson outboard used to do the same thing.
    I am not too worried about it. Most ofthe drivers I use are aware of it.
    No smoke...
    Dave
    Oct 2002
    Ontario
    Thanks for the help guys,
    This Boards is great.
  1. My Mobius with new white rubrail
    By On Board in forum Pride & Joy
    Last Post: 09-18-2007, 03:57 AM
  2. My new 07 LSV - Black-Red and White. FINALLY I have pics!
    By canadasteve in forum General Chat
    Last Post: 05-23-2007, 01:13 PM
  3. Too Much Smoke
    By DOCDRS in forum Service & Repair
    Last Post: 08-03-2006, 06:19 PM
  4. White PVC
    By qb12 in forum General Chat
    Last Post: 07-18-2005, 10:35 AM
