Results 1 to 7 of 7
08-27-2007, 02:24 AM #1Senior Member
- Aug 2007
- Toronto, Ontario
- 187
How much water should be left in the bilge?
Hi. I had a minor wash over the bow today and the auto bilge pumped it out. However, there always seems to be an inch or two of water in the bilge (when I open the engine compartment).
Is this normal? I have a Moomba Outback with a direct drive.
Thanks,
Laz2007 Moomba Outback
99.999% Slalom, 0.001% Wakeboarding
08-27-2007, 04:39 AM #2
Yes, residual is normal. Most of the rest will come out when back on the trailer and remove it the plug
B
08-27-2007, 01:40 PM #3Senior Member
- Mar 2004
- Martinsville,Indiana
- 213
Your bilge pump probably is not at the lowest point in the bilge.I have an 04 LSV and mine was not.It was off to the side a little bit.
John
08-27-2007, 02:18 PM #4
The switch for the automatic bilge will turn on and shut off at a higher level than if you turned the pump on manually just by the location of the switch on the pump.
08-27-2007, 02:45 PM #5Member
- Jul 2007
- Lake Quacumquasit - MASS.
- 31
Bilge Water
I have an 06 Outback and have the exact same issue. The lowest point of the bilge pump is still about an inch above the floor of the boat.
We have had a couple of 'wash overs', the first one was a biggie and we took in about two inches of water into the bilge area. I just sponged out the remaining water so it wouldn't sit down there. But it was quite a bit more that I would have thought the bilge would miss.
Just another reason to open that motor cover and check out what's going on in there.
Chris
08-27-2007, 06:50 PM #6Senior Member
- Mar 2005
- NC
- 115
my 05 LSV has had similar issues. As stated, manually turning on the ballast will get out most of the residual. If I have time (i.e. no one is waiting to use the steep ramp) I will take the plug out right when I start to pull up the ramp. If I can't, I use a shop vac when I get home to get out the rest. Excess water in the bilge can create bigger problems with steering cable and engine rust. I used to just ignore the little bit of water in there until I replaced the steering cable myself this year. I wont make the same mistakes again. Good luck
08-27-2007, 10:11 PM #7Senior Member
- Aug 2007
- Toronto, Ontario
- 187
Thanks for all your replies.
I'm gonna try and keep it dryer.
key left on...= hours...
By bobwells in forum General ChatReplies: 10Last Post: 03-31-2008, 12:28 AM -
07 Mobious LS low temp and water in bilge
By h2oskierrick in forum Service & RepairReplies: 14Last Post: 04-03-2007, 04:19 AM -
water in the bilge
By gcombe74 in forum Service & RepairReplies: 21Last Post: 07-18-2006, 02:02 AM -
Water in Bilge
By seanpatsdad in forum General ChatReplies: 1Last Post: 06-07-2004, 12:37 PM -
Unusualy high Bilge water level?
By Limeyrick in forum Service & RepairReplies: 4Last Post: 03-18-2003, 11:18 AM
