Results 1 to 7 of 7
Thread: adding Wakeplate?
08-23-2007, 02:45 PM #1Junior Member
- May 2007
- Peoria, IL
- 8
adding Wakeplate?
I have a 04 lsv and have been thinking of adding a wakeplate. Is it worth adding or not?
08-24-2007, 10:21 AM #2Senior Member
- Oct 2005
- Central FL
- 791
Does your boat porpoise at high speeds ?
Not sure if the '04 had the stepped convex rear hull design. If so, then the wakeplate is a must IMHO to allow the boat to ride flat. If not, then the wakeplate does almost nothing on a flat hull.
-J
08-24-2007, 04:46 PM #3
i have it on my 03 mobius lsv and will not be without it
on the next boat--does change the wake shape and
handling of the boat
stacy
08-25-2007, 03:12 AM #4Senior Member
- Mar 2004
- Martinsville,Indiana
- 213
jrbishop4
I have the same boat as you.It does help with the wake shape quite a bit.I hydrofoil and use it for that quite a bit.
John
08-26-2007, 01:35 PM #5Member
- Oct 2005
- 80
I would never own another boat without one. Love it! ! !
________
vaaapp vaporizerLast edited by superman; 01-24-2011 at 01:48 PM.
09-02-2007, 08:13 PM #6
i have it one my xlv. never really noticed any big difference in handling, until I accidently broke one of the wakeplate hydrolic pistons. Took the boat out, It porpoised like crazy, couldn't go over 25 without it bouncing all around the place. It makes a huge difference. Plus, it helps shape the size an shape of the wake alot..
desert wake 360
09-07-2007, 09:06 PM #7Junior Member
- Sep 2007
- 15
Have you been quoted a cost to do this? I'm interested in doing the same.
Thanks,
Don
Wakeplate on 01' Outback LS?
By vince737 in forum Wakeboarding | WakeskatingReplies: 4Last Post: 04-20-2007, 01:51 AM -
wakeplate
By drewdwn in forum Wakeboarding | WakeskatingReplies: 1Last Post: 09-19-2006, 07:13 PM -
Wakeplate
By mattjj23 in forum General ChatReplies: 4Last Post: 06-25-2006, 09:35 PM -
Wakeplate
By behockey in forum General ChatReplies: 1Last Post: 10-18-2004, 12:16 PM -
wakeplate
By pike1990 in forum General ChatReplies: 1Last Post: 09-04-2002, 09:24 PM
