Results 1 to 2 of 2
Thread: power to fuel filter
08-09-2007, 02:04 AM #1Junior Member
- Aug 2007
- 1
I can't get any power to my fuel filter. If I directly connect an outside source of power to the filter, it hums and the engine starts and runs... but nothing on its own. Is there a breaker or fuse only for the fuel filter? Also, as I switched out a new battery I accidently put it in backwards and had the cables attached opposite where they should have been... I wonder if this contributed to my problem?? Any ideas?
Brandon
08-09-2007, 03:03 AM #2
Any ideas? People need to know their limitations and go to a mechanic if they're not sure what they are doing. Your working in an area that has fuel and an ignition source and if any mistake is made your first post may be your last. I believe you are talking about the fuel pump next to the filter and there have been previous posts on the oil pressure switch that may be defective but the reversing of the battery would affect any solid state components unless they have diode protection.
Fuel Filter?? Lack of power on fuel throttle
By slalomskier in forum Service & RepairReplies: 8Last Post: 08-02-2007, 03:52 AM -
replace fuel filter with fuel water separator
By vansolo in forum Service & RepairReplies: 4Last Post: 05-04-2007, 12:17 AM -
Fuel Filter
By beckman2713 in forum Service & RepairReplies: 2Last Post: 11-04-2006, 08:37 PM -
Fuel Filter
By mattjj23 in forum General ChatReplies: 1Last Post: 08-14-2006, 07:18 PM -
Fuel Filter
By ezreitter in forum Service & RepairReplies: 1Last Post: 05-29-2004, 05:03 AM
