Results 1 to 3 of 3
Thread: Boat Lift
07-30-2007, 10:22 PM #1Member
- May 2007
- Greensboro, NC
- 44
Boat Lift
Anyone know if the standard boat lifts will support my outback V will about 2,000lbs of ballast in it. jw because i dont have the v drive sacs plumbed out and its a hassle
07-31-2007, 01:08 AM #2
I think a lot of mfg make a 5400lb lift that would probably work. Locally in MN, Vibo, and Floe come to mind.
My concern would be deformation of the hull while on the lift. Even if you run bunks the length of the boat, instead of the more common V-bunks, that much weight could cause some strange loads on the hull when on the lift. Might be cheaper to invest in a better filling/emptying system and go with a cheaper lift (3600lb).
My 3cts.If you believe something to be true, it will be - in it's consequences.
07-31-2007, 11:22 AM #3Senior Member
- Oct 2005
- Central FL
- 791
I totally agree - the lake is supporting the ballast evenly, the lift will cause undo strain on the hull in the areas where you have doubled the weight of the boat.
Get the water out before lifting. I'm SURE you would void any warranty by doing this.
$0.02 donation given.
-J
Boat Lift
By OldeBoy in forum General ChatReplies: 9Last Post: 06-04-2008, 11:05 PM -
boat lift
By liquidlite in forum General ChatReplies: 0Last Post: 02-17-2008, 11:36 PM -
Boat Lift
By Jonathan in forum Boat OwnersReplies: 1Last Post: 06-04-2006, 11:44 PM -
Boat Lift
By jwest2000 in forum Service & RepairReplies: 10Last Post: 04-21-2006, 01:27 PM -
Advice needed: boat winch vs. boat lift
By Rock Laubster in forum General ChatReplies: 2Last Post: 04-17-2006, 09:20 PM
