Thread: Oil Pressure
07-16-2007, 04:42 PM #1
Oil Pressure
The manual states that normal operating oil pressure should be between 20 and 80, and if it falls below this you should shut it down immediately.
I'm wondering if this is at idle or at speed?
My pressure at idle is barely registering above 0. At full speed, it barely exceeds 20. Same thing when towing, around 20.
Oil on the dip stick shows full and my boat is running great with no sign of overheating or any other problems. Are these normal readings or could I have a bad pressure sensor?
07-16-2007, 04:46 PM #2
Yep, possibly a bad sensor or inaccurate guage.
@ idle, 40 couple
runnin' down the river 60+
hope this helps
B
07-16-2007, 05:19 PM #3Senior Member
- Aug 2006
- Millington TN
- 204
Re: Oil Pressure
Originally Posted by TN_BoarderLarry Engelbert
Indmar Marine Engines
"Power to the Sport"
07-16-2007, 06:17 PM #4
Thx Nut,
I was hoping you would reply.
Have I checked everything to feel comfortable running my boat with this pressure reading? Is there anything else I need to check? I'll definitely have the dealer take a look, but it may not be immediately. I don't make it up there too often unless I have to.
I just really noticed this recently and I feel pretty confident it was reading higher before. Like I said, the boat's been running great but I just noticed the low pressure readings the last couple times out.
V-drive oil pressure light
By pman592 in forum Service & RepairReplies: 8Last Post: 06-30-2009, 10:12 AM -
Oil Pressure Sensors
By dtlaine in forum Service & RepairReplies: 1Last Post: 11-03-2007, 07:05 PM -
High Oil Pressure
By AZ_Calling in forum Service & RepairReplies: 3Last Post: 06-07-2005, 03:56 PM -
oil pressure
By jeff b. in forum General ChatReplies: 0Last Post: 05-17-2003, 07:09 PM
