Results 1 to 8 of 8
07-16-2007, 08:47 AM #1
07 LSV Emptying the bags. Do I need to be moving to do it?
I notice a few inches of water some times. Why does it not FULLY empty??
07-16-2007, 09:02 AM #2Senior Member
- Mar 2005
- t-town
- 718
have you "burped" the bags. in saying so when you are filling them up, open the plug and let the air come out.
if there is any air in the bags, then they will no fill and empty all the way.
after you do this correct, they should get as flat as a pancake.
07-16-2007, 05:19 PM #3
If the drain was all the way at the bottom of the bag, it'd empty. My drain is an inch or so up from where the bag lays flat. If I want it empty all the way, I have to channel the water over to the outlet
hope this helps
B
07-16-2007, 11:57 PM #4
My bags never empty all the way. Sounds like I have air in them like qb12 says. How do I open the plug on the front bag when it is under the floor??
After I empty the bags while sitting, I will hit the "Empty" switch again while accelerating slowly. This makes the bow rise and forces the water to the rear of the bags and out the dump hole.
That usually gets a few more gallons out.
Hope that helps.
AlAl
07-17-2007, 07:50 AM #5
Thanks!
07-17-2007, 09:21 AM #6Senior Member
- Mar 2005
- t-town
- 718
Originally Posted by cab13367
07-17-2007, 09:50 PM #7the plug should be on the top of the bag. if it is on the bottom then you have the bags upside down. it is on the other end of the fill/drain plugs.
AlAl
07-18-2007, 09:13 AM #8Senior Member
- Mar 2005
- t-town
- 718
one thing you can do is remove the bag and then roll it from the back end to the front bag applying pressure and the air should pretty much come out the fill/ drain plugs. hope that make sense.
Rear ballast not emptying
By WaterDawg in forum Service & RepairReplies: 4Last Post: 10-30-2007, 06:26 PM -
Moving to Saint Louis, Help...
By drhodes5 in forum General ChatReplies: 10Last Post: 06-06-2007, 06:24 AM -
Ballast not emptying all the way.
By MEDIC151 in forum General ChatReplies: 4Last Post: 06-12-2006, 08:38 AM -
Moving Batteries
By Nboard10 in forum General ChatReplies: 1Last Post: 06-02-2006, 11:07 AM -
Ballast Not Emptying
By wakeboard dad in forum Service & RepairReplies: 1Last Post: 07-21-2004, 07:50 PM
