Thread: Gel Coat Repair?
07-15-2007, 11:29 PM #1Senior Member
- Feb 2007
- Dalton, GA
- 108
Gel Coat Repair?
went to a big tourney this weekend and while tied up in the row of boats and the waves rocking the boats, I have 4 very small dings (nail head) from another boats stainless rub rail screws. I have the number of a local guy who is suppose to be a highly recommended repair man but, I was just curious what and how gel coat repair works. Cars I understand bondo, primer, paint... boats and gel coat I don't have a clue. Just wondering how easy is this and what price range should I expect?
thanks
07-16-2007, 12:05 AM #2Member
- Jun 2007
- 74
was the contest in GA..if so where?
gel repair is a bit trickier than paint work.... lots of sanding is in order.....how old is the boat? you probably can get the gel coat straight from SC and have your repair guy use it so its a dead on match... that is if the boat is pretty new with no fading...
07-16-2007, 11:47 AM #3Senior Member
- Sep 2005
- Austin, Tejas
- 491
I did some repair on my boat and it's actually very easy. No filler is required for small dings. They will just mix the gel to get the color right then add the hardener. It is applied directly to the spot after it has been cleaned. Just let it dry, sand it smooth, then polish it and you're done. I would sand it starting with 400 grit and work my way up to 1000 grit and wet sand it. After that, I put a polishing wheel on my drill and hit it real good. It looks as good as new, you can't even tell.
07-16-2007, 08:05 PM #4Senior Member
- Feb 2007
- Dalton, GA
- 108
It's an 07 Black with only 25 hours and about 4 weeks old. Should have no fade at all I afraid to try and fix it myself, not very mechanically inclined on repairing much of anything
07-16-2007, 08:12 PM #5Senior Member
- Feb 2007
- Dalton, GA
- 108
Will Skier's Choice sell us the gel coat to do such repairs or is it like something only a select group of people can order?
Anyone recommend a good repair man?
Vinyl Repair
By outback 4 in forum Service & RepairReplies: 1Last Post: 04-30-2007, 04:52 PM -
repair maunal
By SkiBoy in forum Service & RepairReplies: 3Last Post: 04-08-2006, 06:04 AM -
repair
By Eagle River in forum Service & RepairReplies: 0Last Post: 08-22-2005, 06:37 PM -
service and repair
By NLindellDC in forum Service & RepairReplies: 0Last Post: 08-31-2004, 12:31 PM -
99 Kanga repair
By Memphish in forum Service & RepairReplies: 3Last Post: 06-13-2003, 03:26 PM
