Results 1 to 6 of 6
Thread: Depth Finder Issues
07-08-2007, 06:58 PM #1Junior Member
- Jul 2007
- 6
Depth Finder Issues
I have a 2006 Mobius LSV with a factory installed depth finder. It functions intermittently while I am driving around. When it stops working it reads ---. It doesn't matter if I am in shallow or deep water sandy bottom or rock bottom. Could someone give me an idea of what things to check for the problem.
07-08-2007, 11:13 PM #2Senior Member
- Jan 2006
- Michigan
- 135
Try opening your compartment and looking at the depth finder. Ours was doing the same thing and we realised it broke loose from the factories installation. We put a bead of silicon around it and it works great.
07-09-2007, 07:40 AM #3Junior Member
- Jul 2007
- 6
I'll check that. Thanks for the info.
07-09-2007, 07:23 PM #4Junior Member
- Apr 2006
- Mount Holly, NC
- 6
Where is the depth finder located? Engine compartment? I'm having the same issues.
07-09-2007, 11:12 PM #5Senior Member
- Jan 2006
- Michigan
- 135
My depth finder is located in the V-drive compartment mounted to the hull. The problem seemed to be that they just mounted the depth finder with epoxy and that vibrates and break off. All other depth finders I've seen have been mounted with silicon so I remounted it with that and it's been working like a charm.
07-09-2007, 11:35 PM #6Senior Member
- Feb 2006
- Fayetteville, GA
- 319
Originally Posted by Chefwong
Note the word "sounder". Silicone is a softer, more plyable compound, and does not transfer the sound waves in the same manner as hardened epoxy does. Take your readings with an even larger grain of salt than normal if you put the sounders back in with silicone.
Depth Finder
By rshea99 in forum Service & RepairReplies: 10Last Post: 09-13-2007, 09:19 PM -
Depth Finder
By jroberts in forum Service & RepairReplies: 3Last Post: 07-17-2007, 12:22 AM -
depth finder
By bamwakeboarder in forum Service & RepairReplies: 3Last Post: 03-19-2007, 09:49 PM -
depth finder
By qb12 in forum General ChatReplies: 13Last Post: 04-01-2005, 10:07 AM -
Depth Guage issues
By Livindadream in forum Service & RepairReplies: 8Last Post: 06-03-2004, 07:05 PM
