Results 1 to 10 of 15
Thread: Tie downs?
07-02-2007, 09:18 PM #1
Tie downs?
OK this may be a dumb question, but do you guys use tie downs for the back of the boat? Just got our 07 Outback and it came with neither tie downs nor a safety chain for the bow eye. Our last boat (99 Sea Ray) had both. Kind of irritating to spend +/- 35k on a boat and not get them included; seems like due to safety reasons they would be.
So I bought some at Academy today, but when I put them on they are situated to where over time I'm sure they would chip the gelcoat on the back of the boat. Granted this is below the platform, but a scratch is a scratch! So do you guys use them and if so what type? Sorry for the long post and stupid question!
07-02-2007, 09:31 PM #2Sled491 Guest
my dealer sold me a pair that are made for boats, and where the buckle (if you want to call it that) is there is a piece of webbing with velcro that wraps around to protect your boat. They work great and fit nicely between the boat and the platform.
I saw them in the Overtons catologue as well.
Good luck and congrats on the new boat, our 07 outback has been great!
07-03-2007, 09:56 AM #3Senior Member
- Oct 2005
- Central FL
- 791
Just discussed a few days ago here:
https://forum.moomba.com/viewtopic.php?t=4391
in short - lots of possibles, most have coated hooks on the boat side to not chip the gelcoat.
And the "I just paid $xxx and this was not included" is the most common statement here (and on all boat boards) - Your Sea Ray was marked up so much that they could have thrown in a pair of skis, vests for all family members, ropes, tie downs, pizza for the first year of ownership, manicures for the ladies, a nice set of dinnerware, and a cool TV set !
You paid $10,000 less than a ma$tercraft, or uncorrect craft. But you bitch about $12 ????
Go enjoy the boat!
-Joe
07-03-2007, 11:33 AM #4
Yes the Sea Ray was marked up, but I knew what I was getting. Everything I needed was included. Don't fool yourself...Moomba's are marked up as well. Bitching over $12 dollars is the entire point..you shouldn't have to.
07-03-2007, 12:30 PM #5
TL7,
I had exactly the same reaction. And as a counter to Joe's point, I bought a low end, 19' stern drive brand new in 1991 for $12k and it came with transom tie downs. When I asked the Moomba dealer about the absence of the tie downs, the response I got was that transom tie downs are not necessary on inboards. The reason stern drives have them is because they are more prone to bouncing up and down due to the outdrive hanging back there. I bought tie-downs anyway.
The ones I got are the ratchet type. Both hooks are vinyl coated and the ratchet device rests against the trailer bunk, not the boat, and have a thick protective webbing as well that prevents the boat (or in my case, the trailer bunk) from being in direct contact with the ratchet. I bought it either at Home Depot or GI Joes, I forget which. I'll try to upload a pic of it tomorrow.
Hope that helps.
AlAl
07-03-2007, 12:33 PM #6
I use tie downs when I travel out of town to satisify the law but I did sew a strip of deck carpeting like on the trailer runners on the end of the webbing next to the hook (so the carpet piece stays attached to the strap)and then I sewed velcro on the ends so the carpet piece is between the hook and the boat and wrapped around the hook and held in place by the velcro. No scratches. The straps go between the boat and the rear deck.
07-03-2007, 05:24 PM #7Member
- Aug 2006
- Reno Nevada
- 51
TL7
I know you probably bought your tie downs already. I went a step further and went to "Wally World" (Walmart) in the automotive section they had seatbelt muffs for a couple of bucks that already have velcro on them. I wrap these around the straps where I think they may damage the gel coat and then velocro them. They give a nice uniform look and help protect the gel coat. I haven't had any problems yet.
My 2cents Hope this is helpful.
Bulldgz - Reno Nv
07-03-2007, 06:13 PM #8Junior Member
- Jan 2007
- Manchester,MO
- 20
Try these tie downs. They are well worth the extra money. They fit perfectly on the trailermate trailer. I have them on my 06 LSV.
http://www.overtons.com/modperl/prod...=32050&aID=26H
07-03-2007, 06:24 PM #9Member
- Aug 2006
- Reno Nevada
- 51
drhodes5
Those are pretty impressive. I think I like your set up better than mine. I may just invest in a a set..
ThanksBulldgz - Reno Nevada "Workin' to live? or Livin' to work? Life is Good!
2003 Moomba Mobius Ls
Blue & White
Updated Tribal Graphics
Boatmate Trailer
07-04-2007, 12:44 AM #10Senior Member
- Oct 2005
- Central FL
- 791
TL7,
To counter Al's reply
The "low end stern drive" still had a greater percent markup. Those things that "line the bay" are made like twinkies. Spray stuff into a mold, it flufs up and then robotically inject filling, then pop it out of the mold before it's done. fluffy and soft, and no substance. sure, they throw in lots of stuff - they have no costs in the boat - they make so many for so little.
Moomba is essentially the same boat as the Supra baring some upgraded amenities. Hand laid glass, thick gelcoat, top quality hardware, top quality engines, same electronics and technology as all the rest - but maybe a year or two older. Each boat is custom built. Each is different. Go buy an orange and blue bayliner. So for the same stuff as a $60k boat, you paid $35k. Percentagewise - there is NOT the Same markup. I'm sure if you told your dealer that above the $1500 off of the already low bottom line he gave you - you made tie downs a deal breaker - he would send Woody from the shop over to k-mart to spend the $12 himself.
Get over it already.
Or buy a Supra or a Mastercraft or Nautique, or Tige or Malibu and ask those dealers to throw in everything - they will still look at you funny, but at least they have $5000 more to play with.
-J
Tie Downs
By smak in forum General ChatReplies: 7Last Post: 06-13-2007, 05:07 PM -
Boat Tie Downs and MFG Responsibility
By BensonWdby in forum Service & RepairReplies: 7Last Post: 03-27-2005, 10:18 AM
