Results 1 to 8 of 8
Thread: Water temp gauge
07-01-2007, 07:09 PM #1Senior Member
- Feb 2007
- Dalton, GA
- 108
Water temp gauge
any ideas on how to put a water temp gauge on an 07 Mob LSV? Just wondering, was out on a friends supra this weekend and it came with this, pretty cool considering we ride in a cold river... usually 62-67 degrees
07-01-2007, 07:53 PM #2
If you have PerfectPass, you already have it. Let me know if you need instructions on how to call it up.
AlAl
07-01-2007, 10:29 PM #3
I have PP on my 06 Outback V,,,will it tell me the water temp too? Ifso let me know how to look it up.
07-01-2007, 11:43 PM #4
With PerfectPass on and the boat in neutral (engine does not have to be running), press the "Menu" and the "^" buttons at the same time. It will take you to a different screen that shows "Contrast", "Name List", and "System Info". Contrast should be highlighted. Press the "Menu" button twice so that "System Info" is highlighted. Press the "^" button to see the water temp (as well as other info).
I think you can actually do this while underway as well. You can also do it while the boat is out of the water (it will give you the ambient air temp). Just turn the key on and follow the steps above.
Hope that helps.
AlAl
07-02-2007, 09:09 PM #5Senior Member
- Feb 2007
- Dalton, GA
- 108
thanks, i will try this wednesday and let you know if it works
07-02-2007, 09:35 PM #6Sled491 Guest
Can you set that up so that the temp stays on the display in the corner or something, or do you have to follow those steps every time?
07-02-2007, 11:33 PM #7
Sled,
As far as I know, you can't. I know, it's ridiculous. The whole user interface is horrible.
AlAl
07-03-2007, 06:21 PM #8Sled491 Guest
Cab,
Your not kidding me, I have my PP so screwed up right now it's not even funny.
Carb and Temp Gauge Probs
By AaronWhitt82 in forum Service & RepairReplies: 26Last Post: 09-15-2007, 08:18 PM -
Trans temp Gauge.
By JesseC in forum General ChatReplies: 0Last Post: 09-19-2006, 01:30 PM -
Temp Gauge Too Hot
By in forum Service & RepairReplies: 6Last Post: 06-27-2006, 12:51 AM -
temp gauge sending unit
By yzblue125 in forum Service & RepairReplies: 3Last Post: 09-16-2005, 01:19 PM -
Temp Gauge
By jrich23 in forum General ChatReplies: 3Last Post: 08-19-2005, 06:34 AM
