Results 1 to 10 of 14
    Lake Village, AR
    Default Vibration after hitting submerged stump
    I'm new to the DD boats (07 Mobius LS). Yesterday I hit a submerged stump. I've done this before with stern drive boats and it just messed up the prop. When I did it yesterday with the DD I figured it did the same thing since the boat would vibrate after idle speed. I was able to get back and load on to the trailer. After pulling out of the water I inspected the prop and there appeared to be no damage to it. My question is could I have gotton the DD out of balance? Any info or advice would be welcomed.
    07 Mobius LS--Razorback Red
    Feb 2007
    tacoma
    i would take another look at the prop and the prop shaft to ensure you didnt bend it
    Oct 2005
    Central FL
    I agree - it takes VERY LITTLE to get vibration. Have the prop resurfaced & rebalanced, or replace it and use this one as a spare.
    -J
    Mar 2003
    Springfield Missouri
    If you have vibration more than likely the prop has been bent. The naked eye won't catch the minor bends but when the prop is turning at a high speed you'll feel the vibration.
    Lake Village, AR
    Thanks, I'll take another look at the prop.
    Aug 2002
    Bismarck, NorthDakota
    Take a look at the strut (brass hanger that the drive shaft goes through)
    I would even hookup water, start the boat, and put it in gear. Then take a look at the prop/shaft, if the shaft is bent you will see it for sure.
    All else fails take it to a shop. Don't mess around with a vibration!
    Bruce Fuerstenberg
    Lake Village, AR
    I checked the saft and strut, even put a level on the shaft. Both seem ok. Had a friend take a look and he thought that the prop may have a slight bend to it. I'm going to contact the dealer today and see if they can take a look at it.
    Aug 2006
    Salt Lake City
    As you have already read, I too am in the same boat. got the new prop from Joe Techie and love it..> I still have some vibes/high pitch squeal at low rpm. When we go to neutral and slow to stop, there is a high pitch squeal as the shaft stops spinning. I am confident it is in the Brass strut that supports the shaft just before the prop.
    MY Question is: Is there a bushing or packing in that STRUT that is replaceable or is there some maintenance that I should do to that piece?
    I think I have found the answer, http://www.skidim.com/prodinfo.asp?number=SB10X12
    How do you remove / replace?
    Thanks and Happy 4th,
    BW
    Brad
    2006 Moomba Mobius LSV sold
    2004 Outback sold
    Lake Village, AR
    I made the 2 1/2 hr drive this morning to the dealer and picked up a new prop. Left the old one with him, he couldn't see any damage either. Put the new one on and everything is back to normal, no vibration. Going to have dealer send old prop to shop for repair and then I'll have a spare. All is right with the world again.
    Aug 2004
    Lake Hickory, North Carolina
    There is a cutlass bearing in the prop shaft strut that can be replaced.
    B
  1. Vibration
    By Longshore in forum Boat Owners
    Last Post: 06-14-2007, 08:00 PM
  2. Submerged Boat
    By Storm in forum General Chat
    Last Post: 08-12-2006, 12:09 AM
  3. Hello Vibration!
    By jpengelbrecht in forum Service & Repair
    Last Post: 08-30-2005, 02:44 PM
  4. Vibration
    By Allterr in forum Service & Repair
    Last Post: 04-16-2004, 07:49 PM
  5. Vibration
    By MartyC in forum General Chat
    Last Post: 05-10-2003, 03:18 AM
