Results 1 to 10 of 10
Thread: Running out of water
06-21-2007, 04:08 PM #1Member
- Jun 2007
- Memphis, Tn.
- 36
Is there any way to run water into the motor while the boat is out of the water need to adjust the carbs and was wanting to try and do it at the house I know your not suppose to run them without water(any motor)just wanting to try and take care of it before I get to the lake.
06-21-2007, 04:12 PM #2Senior Member
- Feb 2006
- Fayetteville, GA
- 319
Re: Running out of water
Originally Posted by rshea99
http://www.overtons.com/modperl/prod...e_Lake_Flusher
http://www.westmarine.com/webapp/wcs...allpartial/0/0
06-21-2007, 04:33 PM #3Member
- Jun 2007
- Memphis, Tn.
- 36
Thanks for the info, new to these types of boats so I figured their had to be something out their to get the job done.
06-21-2007, 09:08 PM #4Senior Member
- Feb 2006
- Fayetteville, GA
- 319
There is also a kit you can get from your dealer that goes inline for flushing out the system.
If you get the "plunger on the stick" model, be sure to have someone watching it while you are bouncing around inside.
I park mine in the grass and bury the end into the ground to keep it from walking away on me.
06-21-2007, 09:42 PM #5
Good job!...you def don't want to run w/o water input...that rubber impellor wouldn't stand a few seconds w/o it
B
06-22-2007, 11:56 AM #6Member
- Jun 2007
- Memphis, Tn.
- 36
What rubber impellor are you talking about. Is this one of these things to keep an eye on.
06-22-2007, 01:32 PM #7
It's in a pump housing mounted on the front of the engine. Usually 4 screws hold the cover on, the impellor is under that cover. Recommended replacement time is once a year.
06-22-2007, 02:18 PM #8Member
- Jun 2007
- Memphis, Tn.
- 36
Thanks again for the tips. I got of race cars because of all the work and time it took to keep it going I am finding out these are the same way but at least its only once a year upkeep and the reward is a whole lot better. I have yet to leave the lake mad and upset because of a bad finish or something got tore up. Thanks again for all the help. If any one is from the Memphis area let me know might be on the same lake some day haven't seen to many other moombas on the water yet I know they are around.
06-24-2007, 03:27 PM #9Senior Member
- Aug 2006
- Millington TN
- 204
Originally Posted by rshea99Larry Engelbert
Indmar Marine Engines
"Power to the Sport"
06-25-2007, 09:30 AM #10Member
- Jun 2007
- Memphis, Tn.
- 36
Thanks Larry.
05 mobius not running
By 05mobiusxlv in forum Service & RepairReplies: 10Last Post: 07-10-2005, 04:04 AM -
WATER TEMP RUNNING HI
By TERRY in forum General ChatReplies: 2Last Post: 06-14-2005, 12:07 PM -
Running out of balance
By Colorado in forum Service & RepairReplies: 5Last Post: 06-14-2004, 09:46 PM -
Running Rough
By cham783 in forum Service & RepairReplies: 2Last Post: 08-15-2003, 05:08 AM -
Running Hot
By wdf in forum Service & RepairReplies: 1Last Post: 06-26-2003, 10:08 PM
