Results 1 to 6 of 6
Thread: Poor starts
06-20-2007, 02:20 PM #1Member
- Jun 2007
- Memphis, Tn.
- 36
Poor starts
I just bought 2002 moomba outback it is hard to get started. I have to give it a good amount of gas to get it started it will run fine after it runs for a while at a high idle, if you shut it off then start it right back up it does fine but if you set on the lake for a while it has trouble again. I found that the float was not hooked up to the electric chock but after fixing that it still has a little trouble starting.
06-20-2007, 03:25 PM #2
Do you get black smoke out of the exhaust during the warm up indicating a little extra too much gas? What is your location? If over 3000-3500 ft, you may have to pop those little caps off the carb adjusting screws and do a little tweaking.
06-20-2007, 03:30 PM #3Member
- Jun 2007
- Memphis, Tn.
- 36
I am located in Memphis, Tn. I get black smoke out of the exhaust after it gets started which tells me it is getting to much fuel not sure on how to adjust the carbs what way do I go on them.
06-20-2007, 03:54 PM #4Senior Member
- Feb 2006
- Fayetteville, GA
- 319
Originally Posted by rshea99
http://www.feather.us/2006/09/01/hob...-bleed-screws/
06-20-2007, 04:22 PM #5Member
- Jun 2007
- Memphis, Tn.
- 36
Thanks for the info. Know its time to see if my mechanic skills are any good.
06-21-2007, 12:19 AM #6
Thanks for the chime-in, W
B
help ... poor cold start
By Aubrey in forum Service & RepairReplies: 7Last Post: 06-17-2007, 10:47 PM -
Engine never starts in iddle
By marchina in forum Service & RepairReplies: 2Last Post: 10-23-2005, 08:33 AM -
XLV bilge design flaw, poor drainage
By Steve23 in forum General ChatReplies: 2Last Post: 02-24-2005, 10:03 PM -
Poor service at Delta sportboats Antioch
By wavedude69 in forum General ChatReplies: 22Last Post: 02-20-2004, 10:21 PM -
Moomba starts then quits
By woodman in forum Service & RepairReplies: 8Last Post: 10-09-2003, 10:40 AM
