Results 1 to 10 of 11
Thread: Trailer Brakes
    May 2006
    Cookeville, TN
    Default Trailer Brakes
    Anyone else had any problems with their trailer vibrating when braking? I thought initially that it was my truck when I was towing with my Tacoma, but now I'm towing with a new Armada and the vibration is still bad. I'm wondering if maybe I have a warped brake rotor on the trailer or is this something to be expected with this type of braking system (actuator).
    Aug 2004
    Lake Hickory, North Carolina
    My trailer 'bucks' a little when being towed and the boat isn't on it. No problems w/ vibration, though. 2004 model w/ single axle
    B
    Dec 2006
    Louisville, Colorado
    I have a 2006 LSV with a single axle trailer. The breaks vibrate when light pressure is applied. The vibration goes away when I really start to break hard. It would be nice to find out if it can be fixed.
    Feb 2007
    tacoma
    are you towing the trailer with the boat on or off? You could pull the tire off and check to make sure everything is all clean also you could check to make sure that on the tongue of the trailer the cylinder doesnt have any obstructions and the pin slot is smooth
    Aug 2004
    Jack the trailer up and check your wheel hub bearing play.
    Grip the tire @ 12:00 and 6:00, wriggle it. There should be no more than an 1/8" movement.
    Hope this helps
    B
    May 2006
    Cookeville, TN
    Quote Originally Posted by kmcg
    I have the same year/model and the problem is exactly as you describe it.
    Mar 2007
    Mesa,Az
    What youare experiencing is normal. When empty there is no weight to put down ward force on axles. What I mean is that the energy being transmitted from the braking force is being transmitted thru the trailer as the weight is nominal to the hydraulic pressure being exuded. My last boat had drum brakes and empty she would do a can-can. You will notice on tractor trailers that when empty the trailer will hop up and down slightly on medium to hard application of air brakes but grab like a mother when loaded. You will get some rotor warping if you put your trailer right in the water with out letting cool for a few minutes. When that happens take the rotors to any NAPA or shop that turns rotors and they can true them up for you
    May 2006
    Cookeville, TN
    I'm experiencing this with the boat on the trailer.
    May 2007
    Naperville, IL
    There is a pretty extensive thread on this problem here:
    https://forum.moomba.com/viewtopic.p...hlight=trailer
    I've got a 2005 trailer and experience the same problem empty. Not much you can do about it. Scares the crap out of my wife on occasion.
    Oct 2005
    Central FL
  1. Trailer brakes locked
    By SEARK in forum Service & Repair
    Last Post: 08-26-2007, 03:17 PM
  2. Trailer brakes
    By kmcg in forum Service & Repair
    Last Post: 03-19-2007, 10:46 PM
  3. trailer brakes
    By Gharvin in forum Service & Repair
    Last Post: 08-03-2006, 05:16 AM
  4. Trailer Brakes
    By in forum Sales & Information
    Last Post: 05-28-2003, 06:37 PM
  5. Trailer Brakes
    By Catdog1 in forum Boat Owners
    Last Post: 04-24-2003, 09:08 PM
