06-14-2007, 11:31 AM #1Junior Member
- Jun 2007
- Minnesota
- 16
Ballast tanks filling on their own.
Hi all,
I've got an 03 mobius and for some reason the left rear and center ballast tanks are filling automatically (without turning the switch on). Has anyone had this issue and if so what might i do to stop this. Thanks
06-14-2007, 03:12 PM #2Senior Member
- Jan 2005
- Alabaster, Alabama
- 143
The solenoid valves for the ballast tanks have manual toggle switches. They need to be flipped to the other position if the ballasts are filling on their own. Either that or it is a sign that it is time to go wakeboarding. Maybe both.
There are pictures in the owner's manual. 2004 manual page 12m-35. Good luck.
Dave
06-14-2007, 10:24 PM #3
Calpal,
Dave A is right - you probably have the manual override switch flipped on on the solenoid. Same thing happened to me - the front bag would fill while we were underway and my 10 year old son happened to remember that the dealer told us about those manual switches on the solenoid. If you have them flipped in the open position, then they are always open regardless of what position the electric switch is on. So when you motor along, the water pressure fills your bags.
Hope that helps.
AlAl
06-15-2007, 08:24 AM #4Junior Member
- Jun 2007
- Minnesota
- 16
thanks a lot to both of you, i'll give that a try
06-15-2007, 06:33 PM #5Junior Member
- Mar 2007
- Mesa,Az
- 29
I had a similar problem on my 06 LSV on our 3rd run in trip at the lake.The first thing to check is the manual bypass. Mine turned out to be the pintle sticking in the bore of the solenoid valve bore. I took it out my self and lightly touch the pintle and it extended out of the bore. I put the valve back in place and re-checked next time at the lake and have had no problems since. Also check for any grit that might have made its way past water inlet screen that can get wedged between pintle and solenoid housing
filling a ballast
By frito in forum General ChatReplies: 4Last Post: 08-09-2007, 11:30 PM -
balast tanks filling with water while cruising?
By rbc_racing in forum Service & RepairReplies: 1Last Post: 08-01-2006, 08:23 AM -
Ballast is filling on its own
By Aquaholic in forum Service & RepairReplies: 4Last Post: 10-24-2005, 09:27 AM -
Ballast Bag Filling Itself! Help!!!
By sailnfast in forum Service & RepairReplies: 3Last Post: 05-02-2005, 08:46 PM -
Tanks not filling up at same rate???
By bluoval in forum General ChatReplies: 0Last Post: 05-25-2004, 09:43 PM
