Results 1 to 3 of 3
Thread: Bilge pump
06-12-2007, 10:41 PM #1Junior Member
- Dec 2006
- Louisville, Colorado
- 29
Bilge pump
I have a 2006 LSV. The bilge pump seems to run too much. It probably turns on every few minutes. The water that is being pumped out is very warm. How often should the pump be running? Any ideas on what to look for?
Thanks for the help.
06-13-2007, 03:28 AM #2
Check your manifold quick drain hose connection. Also check block drain plugs, hoses and the like
Hope this helps
B
06-13-2007, 10:26 AM #3Senior Member
- Oct 2005
- Central FL
- 791
Check the shaft packing and the freshwater intake as well.
Seems that 06 and 07 boats leak a lot from the factory, but simple fixes will keep them nice and dry.
-J
Bilge pump
By silverski in forum Service & RepairReplies: 1Last Post: 06-16-2006, 12:24 PM -
Bilge Pump
By wakerider in forum Service & RepairReplies: 5Last Post: 03-28-2006, 08:26 AM -
Bilge Pump Problem?
By scott016 in forum Service & RepairReplies: 13Last Post: 05-26-2005, 09:07 PM -
bilge pump
By pike1990 in forum Sales & InformationReplies: 1Last Post: 09-04-2002, 11:06 PM -
Bilge pump
By mikeoc in forum Boat OwnersReplies: 1Last Post: 07-29-2002, 07:39 AM
