Results 1 to 7 of 7
    Jan 2006
    Michigan
    Default WAKE SURRRRRRFIN!
    Does anyone in here wakesurf? Try it for the first time today and it was alot of fun. I have a 07 XLV with 2 grand of ballast and I was running about 12 mph. Whats everyone elses set up here? Just trying to find that perfect wake to surf
    Feb 2006
    Fayetteville, GA
    Default Re: WAKE SURRRRRRFIN!
    Quote Originally Posted by Chefwong
    Do a search, Ed_G is the man.
    May 2004
    San Antonio, TX
    I rather wake surf than anything. I enjoy the freedom of not having to hold on to a rope (except to get up of course) I surf goofy foot so I load up balast system pluss a 1000lbs'er I installed under the seat on the drivers side, then make everyone sit on the drivers side and we find our perfect never ending wave at about the 9.5 mph mark. I use a hand held GPS to get it exact. I strongly recommend an exhaust system so you do not get afixiated/die from the exahaust fumes. I use the Fresh air exhaust system and love it.
    http://www.freshairexhaust.com/
    No worries with this system and the folks that own the company are first class people and will take care of you.
    Aug 2006
    how do u guys weight ur boat... i have a 05 LSV. so far i use the front ballst and the side that i do on, and i can surf it but i need to know how i can make it a lot bigger.. the wake plate is allll the way down as well
    May 2004
    San Antonio, TX
    Quote Originally Posted by norcalwake2
    We all surf goofy foot on my boat, so what I do is fill my two 400 lbs balast located on each side of my engine compartment and I load the ballast located in the hull. Then I load an 900lb balast located under the passenger seat directly behind the driver. Then I make everone sit on the drivers side of the boat. I also raise my wake plate all the way in the up possition. I find the speed where my wave is smooth and crisp. Usually around 9.8 MPH.
    Oct 2005
    Central FL
    There is your problem !
    The boat makes a wake with the plate UP. The boat reduces the wake with the plate DOWN. Everywhere in between is to adjust.
    -J
    Aug 2006
    yeah thats what i ment. i have it all the way up my bad..
