Results 1 to 8 of 8
Thread: Tie Downs
    Jan 2005
    Default Tie Downs
    hi boys
    Its been awhile since I visited. I have a question. We will be towing our 2003 Outback with Boatmate trailer alot this year. Normally it sits in the water last couple of years. The marine we deal with has provided the tie downs (rope) in the past. I bought some tie downs but with the Boatmate trailer, swim deck and tow hooks they are too big for the little holes on both. What does the brain trust suggest? Thanks in advance.
    Mar 2003
    Dearborn, Michigan
    I use these; Kwik-LokŪ II 2' Transom Tie-Downs. I think we got them from West Marine but Overtons sells them as well. They have swivels built in to the ends and work really well.
    Oct 2005
    Central FL
    I use these:
    http://www.sportsauthority.com/produ...ductId=1029359
    Innexpensive, vinyl covered so they do not scratch the gel coat, quick-cam lock - so just pull and tight, push the button to release, and they fit between the swim-paltform and the boat.
    -J
    Jan 2005
    thanks
    I have never used any. Probably not the safest but i just dont.
    ________
    starcraft II replays
    Sled491 Guest
    My dealer had some that slip in behind the ski platform and lock below it. These didn't seem all that different from others I have used with other boats I have owned...cost was about 25.00 bucks
    May 2007
    I use these - they will bolt right on the trailer no drilling. the hook is a little large but seems to work just fine.
    http://www.immioutdoors.com/boatbuck...transom_g2.htm
    Feb 2006
    Fayetteville, GA
    Quote Originally Posted by Nimrod
    I like the look of those.
    Dealer torked mine when it was last there. Looks like they tried to back the boat off the trailer with the transoms straps still on. I'm liking these as the replacements
  1. Tie downs?
    By TL7 in forum General Chat
    Last Post: 07-06-2007, 12:19 AM
  2. Boat Tie Downs and MFG Responsibility
    By BensonWdby in forum Service & Repair
    Last Post: 03-27-2005, 10:18 AM
