Results 1 to 10 of 14
Thread: Depth finder
    Jul 2002
    Georgia
    Default Depth finder
    I bought one. However, I have drill a hugh hole somewhere to install the meter. Has anyone done this??? The best placement that I can see is above the throttle.
    Any thoughts?
    Mike
    May 2002
    chicago
    Default depth finder
    I just had a Uniden depth finder installed in my dash below the RPM guage, just to the right of the steering wheel. It fits well.
    I looked into mounting it around the throttle, but thought it might be awkward to look at.....
    I was pleasanty surprised how accurately it reads. The transducer is epoxied to the hull just to the right of the engine block.
    Good luck with install.
    Aug 2002
    Corpus Christi, Texas
    Default Depth Gauge
    I have 03 Mobius LSV and want to install a depth gauge. Did you epoxy the transducer directly to the fiberglass bottom inside the boat? Any help on where to mount the transducer in my boat would be very helpful. Thank you.
    Bobby
    Bobby
    Aug 2002
    Maryville, Tn.
    Default Transducer mount
    If the boat in question is an inboard, the transducer should be mounted about 2" behind the stbd. transmission mount, and between it and the coupler(roughly 2" stbd. of keel centerline). Make sure to sand the mounting area with 80 grit sandpaper, then, apply the 2part epoxy, making sure there are no air voids between the bilge and transducer. This can be achieved by twisting the transducer back and forth gently, until it hits the bilge. If the boat is a V-drive model, the same technique is applied, however, the placement is just fwd. of the speedo p/up, and about 2" port of keel ctr. line. Brian Raymond
    Jul 2002
    Georgia
    I failed to mention, I have 2001 mobius. There does not appear to be a place on the dash to drill a hole. Again, I was thinking about drilling the hole for the meter above the arm rest which id above the throttle.
    Any idea on what would be the best drill bit to use?
    Also, I am going to place the transducer near the bilge.
    Thanks for any suggestions.
    Mike
    Nov 2003
    Binghamton, NY
    I also have a 01 mobius i am looking into getting the piece of trim the 2003 have on the armrest above the throttle. I will let you know how i make out.
    You don't know unless you try
    Nov 2003
    Binghamton, NY
    Mar 2003
    s.e. washington state
    Default Put the depth finder in the dash
    When I bought my Mobius the depth finder was next to the throttle. Very poor location as you can't drive and watch the depths at the same time. I moved the most useless 2" gauge, the voltmeter to that location and placed the depth gauge in the dash. Works much better.
    Now I know why they don't put speedometers in cars on the drivers door...like duh.
    1998 Mobius
    310 HP PCM
    Apr 2003
    Powhatan, VA
    I got frustrated trying to figure out where to mount a dial gauge on the 99 outback.
    So, I installed a humminbird 400tx on the passenger dash.
    Gives digital depth and bottom profile.
    Would not have a simple gauge after using this.
    Keeps me in good graces of the bass and catfish crowd that dominate my ramp, also.
    Here's an old set pictures of an antenna installation. The depth finder is visible through the windshield. This is a great set-up: http://members.cavtel.net/hct
    Jun 2003
    Fort Worth, Texas
    Default Headsup Display
    What we need her fellas is fighter jet technology....like a heads up display. Of course that might just freak out all the Bass and Catfish folks on his launch.
    I'm sure the boys over at Northrop Grumman would share some of their F22 Technology with the good folks at Skiers Choice. Can't hurt to ask.
    Matt Elliott
    2003 Mobius
  1. Depth Finder
    By jroberts in forum Service & Repair
    Last Post: 07-17-2007, 01:22 AM
  2. depth finder help!!
    By hwb06 in forum General Chat
    Last Post: 03-26-2007, 12:33 PM
  3. depth finder
    By bamwakeboarder in forum Service & Repair
    Last Post: 03-19-2007, 10:49 PM
  4. Depth Finder
    By pickle311 in forum General Chat
    Last Post: 11-22-2005, 05:34 PM
  5. depth finder
    By qb12 in forum General Chat
    Last Post: 04-01-2005, 10:07 AM
