Results 1 to 6 of 6
Thread: No fuel at carb
06-03-2007, 08:41 AM #1Junior Member
- Aug 2006
- 4
No fuel at carb
Hi, I have a 2006 outback with carb, 43hrs. I hope my promblem is fuel filter as its not getting gas up to carb. My questions are, size of filter?,what would be fair price of fuel pump?where are fuses located as for fuel pump?
love that Moomba, Thank you.
06-03-2007, 10:24 AM #2
Filter size is 3/8 inlets I use Wix #33033 and keep 2 with 1 always in the
boat toolbox. Are you getting 12volts at the pump? A 12volt tester is great
to have and simple. If you try to start the boat do you hear the pump
run or not? If you hear it run then it probably is not the pump. Located
on the back of the engine is a oil pressure sensor switch which provides
power to the pump after the motor is running I had one of these go bad.
Tip-the pump receives power from the ignition directly at start up and this when you release the key. Lastly it could be Vapor lock oh I hate saying that . Are you using end of last years gas and was it hot out?
The only way to check this is look at gas connections at and upstream from the pump. If you are not absolutely fanatical about connections do not do this these connections can not be damaged or leaking when reconnected as these are the main feeds to the motor. Take it to you dealer.If there is no gas beyond the pump then it is vapor locked. Back to Old school hotrod fuel line priming 101.
06-04-2007, 05:57 AM #3
Check the anti-siphon valve @ the fuel tank. I had a simialr problem.
B
06-04-2007, 08:37 AM #4Senior Member
- Mar 2004
- Martinsville,Indiana
- 213
BLKOUTLS
Excellant trouble shooting.57Tom I would say he covered everything it could be other than make sure there is gas in the tank.
John
06-05-2007, 10:00 PM #5Junior Member
- Aug 2006
- 4
No fuel at carb
well i changed the fuel filter and promblem seems to be gone. the filter is 1/2 inch though. thanks for the imput. it seems the older i get, the more i forget and forums like this help jump start!
07-16-2007, 05:56 PM #6Junior Member
- Jul 2007
- 11
Re: No fuel at carb
Originally Posted by 57tom
where is the fuel filter located?
UPDATE: Carb/Fuel Issues... Boat Runs!
By AaronWhitt82 in forum Service & RepairReplies: 22Last Post: 10-15-2007, 09:53 PM -
Fuel Filter?? Lack of power on fuel throttle
By slalomskier in forum Service & RepairReplies: 8Last Post: 08-02-2007, 03:52 AM -
replace fuel filter with fuel water separator
By vansolo in forum Service & RepairReplies: 4Last Post: 05-04-2007, 12:17 AM -
Fuel Issues / Carb Issues?
By jon_n_andrea in forum Service & RepairReplies: 1Last Post: 07-07-2006, 04:29 AM -
carb versus fuel injection
By 55ChevyBrad in forum Boat OwnersReplies: 3Last Post: 11-10-2003, 07:29 PM
