Results 11 to 15 of 15
06-02-2007, 02:11 PM #11Member
- May 2007
- Greensboro, NC
- 44
where is your intake for the your vdrive sacs, cause i just have the sac in the locker then i have the fly high sacs in the v drive compartments but its a hassle to throw the pump over the boat every time
06-02-2007, 03:24 PM #12Senior Member
- Sep 2005
- Claytor Lake, VA
- 598
From the same pump that supplied the front sac, only now it feeds a manifold with 3 valves.
06-02-2007, 04:27 PM #13This post has instruction I followed to install mine. I have an 05 LSV. Installation was not difficult. On a v drive, install the tee for cooling water in the 1" hose on the drivers side of the thermostat housing. $149 at Skidim.com for OJ system which is what Skiers Choice uses.
AlAl
06-07-2007, 10:44 PM #14Member
- May 2007
- Greensboro, NC
- 44
when you upgarde your Gravity I to the 3 bag system, do you add other pumps or do they all run off of 1 pump?
06-07-2007, 11:23 PM #15
Hi Nate,
The one intake pump feeds all three bags but you add two solenoid controlled valves so that you can direct to which bag(s) you want the water to go.
You add an outlet pump for each new bag. The outlet pump pumps the water directly from that bag and out the outlet hole, so each bag has it's own pump and outlet hole.
Hope that helps.
AlAl
How much ballest
By moombabmf in forum WakeSurfingReplies: 2Last Post: 04-22-2008, 08:59 PM -
Ballest for the bow 05 lsv??? How are you weighing down??
By sethscott in forum General ChatReplies: 2Last Post: 09-21-2007, 12:08 AM -
Kenwood Upgraded Stereo
By cptmoomba in forum Sales & InformationReplies: 15Last Post: 02-07-2007, 01:09 AM -
06 LSV ballest bags
By mschude in forum General ChatReplies: 1Last Post: 06-11-2006, 02:29 PM -
Upgraded Fat Sacs
By 05mobiusxlv in forum General ChatReplies: 10Last Post: 12-05-2005, 11:47 AM
