Results 11 to 16 of 16
    Oct 2005
    Timbuktu (NY)
    Skied behind it this morning. The sound is coming from the circulator. Not as loud as yesterday and the boat runs like new. Smooth acceleration and no noise until rpms get low then the kkkck sound like a scrap every now and then. No sound when rpms are up. Only at idle and in gear or out. We watched the shaft putting it into and out of gear. No slop or vibration.
    99 Outback LS
    Oct 2005
    Timbuktu (NY)
    Checked all brass on shaft. All tight under and above, no slop. Watched it run in and out of gear, no unusual sound or movement. I have always changed the fluid yearly.
    All this started after I put in the replacement circulator. I may have picked up a piece of debris and it bounced around the aluminum backing of the circulator. (tough to pinpoint sound direction with the cowling on) Now I hear a tiny bit of scraping like maybe I mounted the circulator wrong or got a bad part. Like I said, once rpm are above idle no sound and runs great.
    I'm baffled.
    99 Outback LS
    Oct 2005
    Timbuktu (NY)
    I tightened the belt and the noise almost is silent. I don't want to overtighten, but I may go a bit more.
    Oct 2005
    Timbuktu (NY)
    I have three ski runs since I got the new flax packing and tightened the V belt. Runs great no sounds coming from the circulator or shaft area.
    I was worried I had the belt too tight, so I backed it off a bit a while back. I guess I had it too loose as it may have been slipping and affecting the circulator.
    Anyway, all good for now.
    Thanks for your input!
    99 Outback LS
    Jan 2021
    Columbus, Ohio
    Good deal. Sorry.for not replying but you were making your way through the fix.
    Rule of thumb, belt deflection should be no more than the width of the belt. So 1/2" wide belt is up 1/4" and down 1/4", anymore and it is too loose. Again, this is general not specific to your circulator.
    2015 Moomba Mojo Surf Edition - SOLD
    4,000lbs
    Manual Flow
    2025 Mojo - Incoming
    Oct 2005
    Timbuktu (NY)
    Thanks for your help on this. I missed a few runs and chased some sounds, but all is good for now. With a 27 year old boat, things go wrong and I hear 'sounds' now and then.
    I will check the belt again and maybe tighten it a bit, and put that on my check list from now on.
    Shorter season this year as the lake was lowered for dam repair and causeway reconstruction.
    My boat is usually in by May 10th and out by the end of October, and I get around 120 runs in.
    Could hit 60 this year due to chasing boat issues, and not getting it in until late June.
    Thanks again!
    99 Outback LS
