Page 5 of 5 FirstFirst ... 345
Results 41 to 49 of 49
Thread: Not starting
  1. #41
    Jan 2021
    Columbus, Ohio
    Quote Originally Posted by SkiBoy View Post
    Thanks for the info guys. I installed a new modulator, and she runs like a top. Second day out my fuel pressure dropped and she stumbled and died. Added gas to the carb,it fired and quit. I keep a spare fuel pump, installed that and all good. The Gremlin thought he had me............... I was skiing by the end of the day.
    Good to hear you keep the extra pump.
    The modulator makes sense. It's about the only thing left to change before swapping the whole distributor. Glad to hear you are still on the water.
    2015 Moomba Mojo Surf Edition - SOLD
    4,000lbs
    Manual Flow
    2025 Mojo - Incoming
  2. #42
    Oct 2005
    Timbuktu (NY)
    Went out to ski at 8 this morning, lost spark idling across the lake. Jiggled wires, touched all the connections and sensor spots unplugged the modulator and coil, tried all what I have been doing and nothing.
    99 Outback LS
  3. #43
    Jan 2021
    Columbus, Ohio
    You can buy a Clymers manual for indmar engines
    https://a.co/d/bk4Juec
    It has wiring diagrams in it to track down what might be causing the issue.
    The ECM takes in sensor inputs and then dictates when to fire even though you are carburated.
    4,000lbs
    Manual Flow
  4. #44
    Oct 2005
    Timbuktu (NY)
    No ECM on my Outback. I think I will buy an electronic distributor and get some help installing it.
    Marine HEI Electronic Distributor 65K Coil - Compatible with 350 5.7
    99 Outback LS
  5. #45
    Oct 2005
    Timbuktu (NY)
    Ordered a basic replacement distributor. Going to have a mobile marine mechanic help me install it and trace any other spark/ground/wiring issues.
    Will report back.
    99 Outback LS
  6. #46
    Oct 2005
    Timbuktu (NY)
    Finally got the right distributor and installed it today with some help from a mobile marine mechanic. Boat runs great but it sounds a bit different. Maybe because I haven't run it in three weeks.
    What a struggle but I learned some things. Lost about 5 weeks of using my boat, but luckily, I have ski friends on the lake.
    Thanks for all the input.
    99 Outback LS
  7. #47
    Mar 2021
    South Georgia
    What sounds different? Timing set correct?
    Sent from my SM-S721U using Tapatalk
    2021 Moomba Makai
  8. #48
    did it run fine the rest of the season? Culprit was distributor?
    99 Outback LS. Sold
    1998 Response for its flat wake.
  9. #49
    Jan 2021
    Columbus, Ohio
    Finally, the old site is back. Sorry for thebsilence as I couldn't log in.
    Good to hear you got things sorted out.
    Would like to know if te new distributor fixed it and what sound is different.
    You my have some timing a little advanced or it is firing all 8 cylinders now.
    4,000lbs
    Manual Flow
