Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 49
Thread: Not starting
  1. #31
    Oct 2005
    Timbuktu (NY)
    I checked the ground from the battery to the block. It was rusted heavily. I backed it out cleaned the threads put some dielectric grease on, and it fired right up. I think I have a gremlin somewhere, but at least for now it's running. Will check back once I find the real culprit.
    Thanks for the info!
    99 Outback LS
  2. #32
    Jan 2021
    Columbus, Ohio
    Still on the water?
    Did it no start again?
    2015 Moomba Mojo Surf Edition - SOLD
    4,000lbs
    Manual Flow
    2025 Mojo - Incoming
  3. #33
    Oct 2005
    Timbuktu (NY)
    Still starting on first turn of the key. It may have been the ground connection the entire time. I am happy with the new plugs, coil and ignition.
    I will update if anything else occurs. Thanks!
    99 Outback LS
  4. #34
    Oct 2005
    Timbuktu (NY)
    Still on the water?
    Went another two weeks without an issue. This morning would mot spark. Fiddled with ignition, tightened battery and checked ground and it started. Second ski run it died under power and will not spark.
    Only would not start after sitting 48 or more hours.
    Once running it never failed to start. This time I skied and then it died as we idled out for another run.
    99 Outback LS
  5. #35
    Oct 2005
    Timbuktu (NY)
    Pulled the rotor and there is all kinds of rust on the distributor. I hate chasing a problem by buying parts, but I think this could be it. Checked ground wires and as many connections as I could and no luck getting spark. Will check where I get spark tomorrow by pulling a plug and testing the spark there and from the coil to the distributor.
    I have seen the new dist. that have the coil in them. Anyone know how difficult they are to set up?
    99 Outback LS
  6. #36
    Jan 2021
    Columbus, Ohio
    The easiest way to check for spark is a timing light. Just put the clamp around each wire and crank the engine.
    If you change the distributor the only hard part is making sure the engine is at top dead center before pulling it. If you get that correct it is a 1hr job. Mark the cap (old and new) which plug goes to which spot on the cap. Firing order is stand small block chevy 18435672. If you are looking at the belt drive, 1357 is on the right, 2468 is on the left.
    4,000lbs
    Manual Flow
  7. #37
    Mar 2021
    South Georgia
    That is just one of those numbers I grew up knowing that I will never be able to forget. LOL! Sort of like "8675309" anybody know that one?
    Sent from my SM-S721U using Tapatalk
    2021 Moomba Makai
  8. #38
    Jan 2021
    Columbus, Ohio
    Yep. I can build a SBC without even thinking. Like most that is just something you never forget.
    And I think most people know Jenny's number.....lmao
    4,000lbs
    Manual Flow
  9. #39
    Mar 2021
    South Georgia
    LOL!! Yep! Every now and then when someone asks me for my cell number, I will say that. Some people laugh and get it right away, but some will just type it in with no clue, then I look silly having to tell them it's not real. Just a nerdy thing I do. .
    2021 Moomba Makai
  10. #40
    Oct 2005
    Timbuktu (NY)
    Thanks for the info guys. I installed a new modulator, and she runs like a top. Second day out my fuel pressure dropped and she stumbled and died. Added gas to the carb,it fired and quit. I keep a spare fuel pump, installed that and all good. The Gremlin thought he had me............... I was skiing by the end of the day.
    99 Outback LS
