Results 1 to 8 of 8
Thread: How much weight?
05-23-2007, 08:46 AM #1Member
- Oct 2005
- 80
How much weight?
How much weight are in the factory 2002 Mobius LSV rear ballast?
I think it is 250lb each is that right?
Also how much weight and what type bags should i drop in the rear for wakesurfing? What will fit?
________
CRF450RLast edited by superman; 01-24-2011 at 01:44 PM.
05-23-2007, 09:09 AM #2Senior Member
- Mar 2005
- t-town
- 718
250 is correct if they are the original factory bags.
need more weight.
i run 2 400's in the back along with pop-products. they are really a neat product because they come in 10 40 pound bags of steel (NOT LEAD) shot. you can easily move them around to where you are needing more weight.
db
05-23-2007, 11:26 AM #3
Re: How much weight?
Originally Posted by superman15 Mondo Surf Edition
02 LSV - Traded In
05-23-2007, 05:15 PM #4Member
- Oct 2005
- 80
Thanks alot guys. I have been thinking about ordering the fly high 400lb bags. Will i need to change out the fittings on my factory inlet and outlet hoses? If so where and what do i order? Thanks
________
mac gamesLast edited by superman; 01-24-2011 at 01:44 PM.
05-23-2007, 05:25 PM #5Senior Member
- Mar 2005
- t-town
- 718
just take the fitting off the 250's and they will go directly into the 400's.
wakeside, barts, overtons and so forth carry the bags. they are all about the same price.
i personally use wakeside the most because of the free shipping, right now they have $3 buck 3 day shipping and the bonus points rewards program.
db
05-23-2007, 10:34 PM #6Originally Posted by qb12
I ended up with 6 of the bag fittings and six of the 90 degree fittings. I added a vent valve/overflow tube to my bags which was the reason for the 2 extra bag and 2 extra 90 degree connectors.
Here is where I got my sacs.
http://www.wakeside.com/page/W/PROD/...drive_sac_W701
Here are the fittings:
These go on the bag:
http://www.wakeside.com/page/w/PROD/...x_fitting_W736
These go on the existing hose:
90 degree connector:
http://www.wakeside.com/page/w/PROD/...x_fitting_W742
Straight Connector:
http://www.wakeside.com/page/w/PROD/...x_fitting_W740
02 LSV - Traded In
05-24-2007, 08:33 AM #7Member
- Oct 2005
- 80
Looks like i will need new fittings to. Thanks .
________
CT110Last edited by superman; 01-24-2011 at 01:45 PM.
05-24-2007, 09:50 AM #8
If you need any pics of my setup, please let me know. I ground off a couple of screws that I was worried would damage the bags as well as removing the cover that covers tha gas filler hose. IT stuck out too far and was simply cosmetic so I removed it. The last thing I did was added a vent valve/overflow to the third inlet on the bag to vent the air out of the bag, plus act as an overflow if the bag fillers is left on.
02 LSV - Traded In
Weigh too much weight???
By BlunderDownUnder in forum Service & RepairReplies: 1Last Post: 07-18-2007, 08:06 AM -
how much weight do I need?
By INlakeOutback in forum Wakeboarding | WakeskatingReplies: 4Last Post: 06-15-2007, 08:07 AM -
tounge weight
By mfiduccia in forum General ChatReplies: 2Last Post: 06-10-2007, 04:58 AM -
2001 Mobius LS weight with trailer weight?
By pmarti15 in forum Sales & InformationReplies: 9Last Post: 05-17-2006, 04:41 PM -
Weight of 05 LSV Ballasts
By sbagley in forum General ChatReplies: 6Last Post: 08-11-2005, 02:21 PM
