Results 1 to 6 of 6
    Nov 2023
    Default 2016 Moomba Mojo V Drive oil leak
    My V drive oil reservoir is leaking. Anyone have a repair manual or know where to get one? I want to tackle this myself. Also need a parts schematic with part numbers.
    Thank you!
    Jan 2021
    Columbus, Ohio
    V-Drive reservoir?
    You mean the case is cracked? The v-drive and fluids are all self contained.
    Do you have pictures so we can try to help?
    2015 Moomba Mojo Surf Edition
    4,000lbs
    Manual Flow
    Sep 2005
    Claytor Lake, VA
    Mine had a small leak at the bottom cover. I took the cover off and replaced the very thin paper gasket with RTV gasket sealer.
    2005 Mobius LSV
    325 EFI
    Nov 2023
    Not sure yet where the leak is coming from. I need to pull it out of the water, clean up the oil and find the spot where it is leaking from. I will send pictures.
    Apr 2013
    Knoxville TN
    Quote Originally Posted by VA LSV View Post
    These are the only leaks I've heard of over the years. Not common.
    2018 Supra SL400
    Jan 2021
    Columbus, Ohio
    If the v-drive is over filled, when it gets hot or under heavy load, the fluid can burp out of the vent on top. It's painted black and it a metal cover over the vent tube.
    4,000lbs
    Manual Flow
