After a few days of high temps and humidity, I finally got back out to the boat today to check things out. With my head held down in shame, I'm reporting back to share that it was indeed the main raw water line valve in the closed position. The valve had been closed by the tech who winterized the boat at the end of last year. This is the first time they've done that in the six seasons we've had it winterized by this shop.
Originally, I confused the raw water thru-hull inlet for the ballast inlet, which was in the open position. When I went out today to check, I remembered what you all had said about the raw water inlet going directly to the v-drive and when I reached in through the hatch, and felt that the handle was perpendicular to the hose, unlike the others, I knew right then it was closed. I emailed the shop on Monday and they too confirmed that their tech remembers closing it - I didn't trust his account because he mentioned the valve was near the front of the boat which made no sense to me.
Anyway, mystery solved. Makes perfect sense now. Definitely odd for the raw water inlet to have clogged within minutes of running after it had been winterized.
I replaced the impeller and seal with a new one - so at least that's done.
On the bright side, thanks to you all, I learned a bit more about the water system. I learned how to swap the impeller which I hadn't done yet.
Engine sounds and runs smoothly. Hoping for no lasting damage due to overheating.
Thanks for the help.
2017 Moomba Mondo Surf Edition
Do not beat yourself up too bad....your friends and family will do that enough...hahaha
Good you learned some things in the process that is what life is about.
As for the temps, if 235 is all you saw the boat should be fine. Did you antifreeze tank overflow? If you have to add antifreeze there is a certain way to do it so it doesn't airlock and overheat. I can help you with that also, so just ask.
Have a good weekend
2015 Moomba Mojo Surf Edition
4,000lbs
Manual Flow
Thanks again. The antifreeze burped over a bit but the reservoir is still half full - it should probably be topped off. Is there a procedure to top it off even if the reservoir has fluid in it?
If the reservoir is still above the hose you are good.
It only is an issue if you get air in the system. Just top off the container and you are good.
4,000lbs
Manual Flow
After you run the boat once or twice, keep an eye on the reservoir levels. If you have air in the system, it usually purges, then you need to add a little more fluid - but you are probably good.
2018 Supra SL400
