Results 1 to 5 of 5
    Feb 2021
    Lexington, KY
    Default Autowake showing bags full when actually empty
    So I finally got my boat in the water over the 4th of July. I put it in and it fired without issue, except for one.
    The 11" screen shows my bow ballast bag as full. It is completely empty. I can try to fill it but Autowake keeps shutting it off.
    Anyone else come across a similar problem? Possible solutions?
    2022 Moomba Mondo
    Jan 2021
    Columbus, Ohio
    Quote Originally Posted by SSurfer321 View Post
    If you go into system settings you should be able to reset ballast level to empty or full.
    2015 Moomba Mojo Surf Edition
    4,000lbs
    Manual Flow
    Feb 2021
    Lexington, KY
    Thanks. I'll give that a shot this weekend.
    2022 Moomba Mondo
    Feb 2021
    Lexington, KY
    Thanks for the tip. That fixed it.
    2022 Moomba Mondo
    Jan 2021
    Columbus, Ohio
    Good to hear it was a simple fix.
    4,000lbs
    Manual Flow
