Results 1 to 5 of 5
    Sep 2017
    North Carolina
    Default Heath Exchanger Gasket leaking
    It seems that the lower gasket on my heat exchanger has started leaking. I tried one trick I saw online and pulled it off, flipped it over and put the end cap back on. I need to see if I maybe put it on too tight, but I am still getting leaking out of it. The gasket itself didn’t look to be in bad shape, just a little deformation on it in the areas that don’t contact the cross bars (not sure what they are called) and it seemed pliable and not cracked.
    I tried to find a new gasket, but the only place I could find the engine diagrams was on the Indmar AU website, and they list the part as a 6” heat exchanger gasket (part number 1977222, listed on the diagram as 277.2 - https://www.indmar.com.au/enginesche...-system-2.html). There is no way this is a 6” wide part, but even then, the one listed on the Indmar AU site doesn’t have the hole through it for the drain plug.
    Anyone have any suggestions for what to look for on the end cap or gasket for why it’s still leaking? Note that the engine temps are solid, generally running right at 165 or so. So the exchanger is getting enough water. It’s just that the bilge pump has to run every so often to pump water. Flipping the gasket and reseating it seemed to have helped reduce the amount of water, but I’m still getting enough that the bilge has to run every so often.
    2017 Moomba Craz Surf Edition
    High altitude prop
    1140 lb WakeMakers Universal Fit rear ballast upgrade
    Autowake 2.0 firmware upgrade (20171121 version)
    2013 SeaDoo GTI135SE with ski mode
    1984 SeaRay 210 CC - traded
    Mar 2021
    South Georgia
    Maybe apply a thin smear of RTV on it and then put it back on?
    2021 Moomba Makai
    Default Heat exchanger gasket leaking
    Quote Originally Posted by chezdude View Post
    Having the same issue and wondering how you resolved it.
    Thanks!
    Sep 2017
    North Carolina
    Quote Originally Posted by shall View Post
    Thanks!
    I just removed the bottom cover, took the gasket and made sure it was clean, lined it back up on the plate and carefully screwed it back down. The hardest part was making sure it didn’t rotate relative to the draincock.
    I have had the boat out a few times so far this season and the issue seems to be gone.
    High altitude prop
    Mar 2021
    South Georgia
    Never had mine off before, so I am shooting in the dark about what it looks like,but can you spread a thin coat of RTV silicon gasket maker on it?
    Sent from my SM-S721U using Tapatalk
    2021 Moomba Makai
Tags for this Thread
