Results 11 to 20 of 25
    Salt Lake City, Utah
    thanks guys for all the help. I ordered the new part and will put it all back together, refill the coolant and keep an eye on things. The coolant is propylene glycol and needs to be 50/50 mix with water right? Where is the best place to buy it?
    Scott
    2021 Craz
    1997 Sea Ray 190
    Aug 2021
    Knoxville
    I got it at Oreillys. Only place near me that actually carried it without purchasing thru dealer
    2019 Craz
    OJ 950
    Wakemakers bags
    Heatercraft triple heater
    Nov 2016
    Knoxville, TN
    Quote Originally Posted by Mxmark4 View Post
    Napa has premix propylene glycol, Brand name Sierra Peak. Used it on my Mojo and SA
    2011 Sea-Doo Wake 155
    May 2018
    Also Prestone Low Tox is readily available
    2021 Supra SA 400
    2018 Supra SA 400 (SOLD)
    Michigan
    Aug 2019
    Where is the pump located? Is it easy to see for regular inspections?
    Sent from my SM-S911U using Tapatalk
    May 2018
    Quote Originally Posted by cucv View Post
    Usually towards the upper forward area of the engine bay behind a access panel. Very easy area to service
    2021 Supra SA 400
    Michigan
    Mar 2003
    Springfield Missouri
    Interesting that the pump is designed for Rv fresh water pumping. The water temperature going through would be at ambient whereas this application would be at the coolant temperature. Could that be an issue with the case cracking?
    SOLD
    Nov 2020
    This is also what I used to refill coolant.
    Can this be added into the OEM Indmar coolant ( mixed with) or do i need to drain/flush the whole system and refill with this?
    Scott
    2021 Craz
    1997 Sea Ray 190
    May 2018
    All propylene glycol coolant brands are compatible.
    Peak or Prestone likely make and rebrand for Indmar.
    2021 Supra SA 400
    Michigan
